Results 1 to 10 of 53
Thread: Truck lift - Your opinion is wanted!
Threaded View
  1. #36
    So your list should be looking something like this
    Springs
    Shocks
    Steering damper
    Drop Boxes (Chase some bolt up ones that require no cutting)
    1 x Brake line (move back to front and replace back)
    Brake bias Plate
    Front and Rear Panards
    adjustable upper control arms
    OPTIONS
    Tail Shaft spacer
    Front Drag Link
    Rear Lower Trailing arms standard length
    Double Cardin Joint in rear tail shaft.
    Robo (25th August 2012)
