Results 1 to 7 of 7
Thread: replace converter or not??
    Jun 2011
    Tasmania
    Hi Guys and Gals, you may have read my post about my auto having no thgird and fourth gear, well ive pulled it out in frustration and am about to install another second hand one but it didnt come with the converter, so my question is shoul I install the old one with it??? how can I tell if its any good???
    Cheers Mark.
    Banned
    Quote Originally Posted by MarkGQ View Post
    Cheers Mark.
    Good question Mark,
    The rule of thumb is: You never use a converter from a trans thats lost gears or has blown because the clutch materials & metal fragments that come from this kind of damage ends up in your converter & even if your converter isn't damaged already & you fit it into another trans the materials will end up being pumped right through your new trans & damaging it as well along with your converter.
    My best advice is to try & get the converter that came from the trans you have picked up or get yours services or changed over. Also never fit a converter to a trans without replacing thr converter seal. If you don't & it leaks the only way to fix it is to remove the trans, pull the converter out to changer the seal.
    I make a habit of changing them when fitting a S/H auto trans just to be on the safe side anyway whether it needs it or not. It a cheap part & 10 min work which to me means piece of mind.
  3. The Following User Says Thank You to patch697 For This Useful Post:
    MarkGQ (20th June 2011)
    Jun 2011
    Tasmania
    Yeh thats good advice I never thought of the old stuff pumping thru the new auto, and yep Ill get a new seal tomorrow and probably a new convertor too as the other one is 5 hour round trip from me. Damn good advise Patch cheers mate.
    Mark.
  5. The Following User Says Thank You to MarkGQ For This Useful Post:
    patch697 (20th June 2011)
    Banned
    Mark.
    How trustworthy is this trans you got Mark??? It would play to have it checked & serviced while its out.
    Jun 2011
    Tasmania
    should be right his pretty trustworthy, having said that, things still happen I know but the worst is I just dont have the funds right now to do that unfortunatly.
    Banned
    Yeah we all know that feeling mate..... Do what you can & keep us posted. If you need anything just check with us here first, it may save you a few it may not but if we can we will here so don't hesitate to ask.
    All the best mate
    Paul
  9. The Following User Says Thank You to patch697 For This Useful Post:
  10. #7
    Patrol Guru Ade's Avatar
    Apr 2011
    Sabah, North Borneo
    Paul[/QUOTE]
    Yup..well known to me. All the best Mark..
  11. The Following User Says Thank You to Ade For This Useful Post:
