Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Another bee sting - cant get horn to work in GQ Patrol
    May 2019
    The man loves to live dangerously! No fuse needed.
  2. #12
    Quote Originally Posted by Eatmyshortz View Post
    Fuses are for sissys!
  3. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (7th February 2024), Eatmyshortz (7th February 2024)
  4. #13
    The feed is from an accessory fuse panel, so yes its fused, I have generated more than my share of smoke events to not go that path!
  5. #14
    Haha! No doubt you have old mate! I've seen the bird nest/ wiring in your Patrol pre rebuild. Its a surprise you have burnt the whole vehicle down yet.
  6. #15
    Oct 2024
    Based on what you’ve described, it could be worth checking if there’s any resistance in the earth connection, even if everything seems fine visually. A weak or intermittent ground could cause that “squeaking” noise since it’s not allowing enough current to flow through the circuit. I’ve seen this kind of issue before where the connection looks solid, but cleaning or tightening it up fixes the problem.
    If you’re still stumped, you might want to check out bosshorn.com for some additional tips or parts that could help troubleshoot electrical components like this. They’ve got some resources that could be handy for figuring out what’s going wrong.
  7. The Following 2 Users Say Thank You to MouLik For This Useful Post:
    MudRunnerTD (7th October 2024), PeeBee (23rd October 2024)
