Page 64 of 77 FirstFirst ... 6263646566 ... LastLast
Results 631 to 640 of 762
Thread: Jay see 1997 GU build up
  1. #631
    Need some suggestions on springs please.
    What experience have you guys had good or bad with different brands. Tough dog, Dobinsons, EFS, OMG, KIng springs Pedders....
    I currently have 2" flexie coils matched with 4" shocks and I'm happy with this set up, but I can't find anyone that makes them now.
    Definitely want to stay at 2" lift.
  2. The Following User Says Thank You to jay see For This Useful Post:
    MB (6th December 2022)
  3. #632
    483 Post(s)
    G’day John Mate
    Bang for buck, I’ve been very happy with Dobinsons coils 4 corners for about 5ish + maybe 10 years now across GU’s & Q’s, maybe a baby Maverick too
    Up front honestly though, far from a suspension expert I am but have replaced some of the originally bought ‘variable rate’ versions/variants with ‘constant rate’ near equivalents.
    Reason being, I personally nuffy found that the variables (although greater load listed) than constant equivalents of lesser ratings listed sagged after a lot less after true variable alternating punishment if that makes sense
  4. The Following User Says Thank You to MB For This Useful Post:
    jay see (7th December 2022)
  5. #633
    We'll today didn't go as planned. Was meant to be a straight in and out with the new springs and fit up the new sway bar links.
    Swapped out the old springs, and discovered that 3 out of 4 shocks have no return in them. I checked them all when I started having the lean issue and all were fine. Anyway the old suspension set up is 7 years old and around 150,000 km , so probably over due, shocks are 41mm tough dog foam cell,
    Recommendations, stay with tough dog (which I've been happy with) or go with something else..
  6. #634
    483 Post(s)
    Bang for buck proclaiming again John Mate, Dobinsons now have 3 levels/range of coin shock
    Original, twin tubes which have always (last decade) served me cost wise happily very well & their remote reservoir full tilt more expensive performance variants unfortunately out of reach. Worth checking out their middle of the range/performance IMS shocks:
    https://dobinsons.com/suspension/shock-absorbers/ims
  7. The Following 2 Users Say Thank You to MB For This Useful Post:
    jay see (18th December 2022), PeeBee (18th December 2022)
  8. #635
    Always mate, always..
  9. The Following User Says Thank You to jay see For This Useful Post:
    MB (18th December 2022)
  10. #636
    483 Post(s)
    Meant meself you Duffa
    FWIW: Was convinced by Young GQ owner Legend on the counter in Dandenong to spend the extra coupla hundgy on the mid-range for our Baby Short Mav
  11. #637
    Well I was hoping on possibly being the first GU on club reg, still might happen only taking a bit longer than expected..
    Being buying up the last few weeks and today was patrol day.
    New Springs and shocks (took @MB advice) and rear brake pads. Steering wheel and radio surround was a good score at the local wreckers.
    Old tough dog foam cell did around 150,000 km in 7-8 years and now have no return. Replacing the 25 year steering with one with no rips and I reckon the best score was the radio surround with only 2 little screw holes and nothing else, never seen one without and antenna switch.
    Question on the sway bar links..
    You can see that once I cut the thread to size it won't line up straight to the bar, if I force it, it will have a lot of pressure against it. What am I missing here.
    Can't wait to get this thing back on the road..
  12. #638
    The rod will pivot in the rubbers, my front and rear sway bars were the same, not a lot of accuracy intended.
    jay see (16th January 2023)
  14. #639
    John, did you take the car into their workshop and get them to weigh it, each corner before selecting the springs? Did they fit the springs or you? I had them do the lot to ensure the right 'numbers' went into the spring selector and ensure it was sitting flat after the job. I have dobbo springs and like them and their service. I use the Dandenong workshop.
  15. The Following User Says Thank You to PeeBee For This Useful Post:
  16. #640
    Thanks for clearing that up..
    No, I didn't know that they offered that service. I ordered the springs through road runner and discovered the shocks were no good a couple of weeks later and ordered the IMS with road runner again.
    Would have done the same if I knew..
