Results 11 to 20 of 29
Thread: run away diesels
    177 Post(s)
    We had a Hino truck runaway on us about 10 years ago. It's a cherry picker truck setup and it isn't fun being 15m up in the air when the all of a sudden the motor starts revving it's gaskets off... and no emergency stops worked!
  2. The Following User Says Thank You to Hodge For This Useful Post:
    mudnut (27th September 2016)
  3. #12
    Expert tuckertrucker's Avatar
    Aug 2015
    Far North, New Zealand
    Runaway is most commonly added fuel from a different source such as what I just experienced by a seal on a turbo letting oil through the intake.
    The oil is then the fuel for the engine not diesel so a fuel cut off will not do anything.
    To stop a runaway you would need to stop air, a snorkel would be a winner by blocking the snorkel and starving the runaway engine of air or to try and stall the engine.
    Yeah I just suffered the same thing.... oil seal in turbo blew and oil blew through the intake. Engine very quickly climbed to 3500 and with my foot on the brake I pulled into the nearest drive way and stole their garden hose, soaked my shirt and wrapped it around the filter. Starved it of fuel and after about 10 seconds the engine stalled itself.
    Then a rather red faced home owner comes running out wondering what all the noise was and why there was a shirtless fat shit standing in his driveway
    1992 Nissan Safari Granroad LWB TD42 after market turbo RE4R03A (for now) 3" straight pipe
  4. The Following User Says Thank You to tuckertrucker For This Useful Post:
    AB (1st October 2016)
  5. #13
    Sep 2022
    kettering
    Quote Originally Posted by jman69 View Post
    Hi there, have just been watching youtube videos on runaway diesels. Would a simple fix be to have a fuel cut off switch fitted in the cabin? Seems to me to be a logical answer to this problem. What do others think?
    Hi !
    Air intake shut off systems are the only proven, reliable method to stop a diesel engine once it has begun to run away. IMO of course
  6. #14
    Nov 2019
    Perth
    5 Post(s)
    I've had this happen on 2-stroke dirt bikes when they are hot enough and lean out, only lasts for about 20-30 seconds though.
    2008 CRD Auto Wagon
  7. #15
    483 Post(s)
    Tomahawks Maybe
    We’ve ALL got one handy at ALL times
  8. #16
    483 Post(s)
    Crowbar, Shovel, Spade (USA), Anythink sharp I learned but never fortunately have had to try cutting off wicked compressors running Intake
  9. #17
    177 Post(s)
    Ha! Hows about a runaway petrol? Kind of, sort of.... Early bird visit to the butchers before GF crowds supply stock-up this morning and saw a bunch of folks around a popped Y62 bonnet in the car park. Car won't shut off. Keeps on idling. Key in/out, button presses did nothing. Positive 12v disconnect killed it swiftly.
    Got me thinking. TD is a dumb diesel motor. Older non-electricy ones would keep on trucking without 12v once started.
    But how about the new-ish ones with that NATs shut-off valve on the pump and the #1 injector somehow being tied electrically (nuffy here speaking).
    Would they shut off without 12v?
    Our old TD42 still need 12V to keep the fuel solenoid open.
  11. The Following User Says Thank You to Winnie For This Useful Post:
    Hodge (24th September 2022)
  12. #19
    177 Post(s)
    Really ??
    We took a battery out of a running GQ and put it into a dead alternator/ battery, Dmax so we could limp it to towable grounds.
    GQ kept chugging along.
    Sent from my Pixel 6 using Tapatalk
    84 Post(s)
    Really ??
    Didn't kill the alternator on the Q? The regulators really do not like having an open circuit.
