Results 1 to 10 of 17
Thread: engine swap on a gu series 4
    May 2018
    hello to all. my zd30 decided it didn't want run any more, so i am swapping over to a 4.2. i have a few queries about parts that may need to be changed. i no the bell housing is different but can i use the gearbox thats in the car? i have engine mounts for the 4.2 as they are different. i know i will have to do a bit of rewiring. would there be any other major changes that would need to be done.
    thanx all for youre time.
  2. The Following User Says Thank You to moparcm For This Useful Post:
    MB (24th July 2022)
    483 Post(s)
    G’day @moparcm Mate
    Have you sourced an engine yet, is it a TD42 or TD42T or TD42Ti ?
    May 2018
    yes i already have the engine
    483 Post(s)
    Which one Mate?
    477 Post(s)
    You can use the ZD belhousing but you need to modify where the starter mounts.
    If you have the wide radiator, not the skinny tall one, you can use this just need TD hoses ,including heater hoses.
    The gearbox is fine to use.
    The crossmember you will need a TD one as this pushes the motor forward 10mm. Otherwise in reverse the exhaust manifold hits the firewall.
    Get Killa Kustoms to mod your loom, so much easier than trying to work it out your self.
    You'll need the weld on engine mount brackets to weld to the chassis. Patrol a Part sell these.
    TD accelerator pedal and cable.
    Clutch and flywheel of course, although I am told the ZD clutch fits. Just get the right one though and be done with it.
    Thats pretty much it from memory.
  7. The Following 4 Users Say Thank You to mudski For This Useful Post:
    Bidja (30th July 2022), MB (25th July 2022), mihit (25th July 2022), moparcm (27th July 2022)
    Which one Mate?
    Sheesh....
    Gong him Red!!
  9. #7
    May 2018
    G’day @moparcm Mate
    it is a td42t
  10. The Following User Says Thank You to moparcm For This Useful Post:
    MB (26th July 2022)
  11. #8
    May 2018
    thanx for the info.
    i do have the td42 bell housing. have also just got a new radiator to suit both the zd and td. using the td crossmember will it affect the tail shafts at all?
    i have got the engine mount brackets from patrol a part. also have the pedal amd cable. my dad is a whiz with wiring so will leave that up to him.
  12. #9
    477 Post(s)
    Quote Originally Posted by moparcm View Post
    thanx for the info.
    It won’t worry the tailshafts at all. There’s plenty of room for movement.
    If your doing the wiring yourself your gonna need the adapter thingo for the tacho. Not sure what it’s called sorry.
  13. #10
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    "adapter thingo" = Dakota Digital SGI-8E
    John
  14. The Following 3 Users Say Thank You to jff45 For This Useful Post:
    BrazilianY60 (27th July 2022), MB (26th July 2022), mudski (26th July 2022)
