Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: GQ LWB Roller or GU LWB roller with 3.0L manual gearbox and transfer case
  1. #31
    198 Post(s)
    Ok thanks all, just zoning in on the details and have a couple of ways of checking now.
  2. #32
    476 Post(s)
    Dang, I honestly thought you deliberately installed that Mark Mate?
    What year ZD?
    2001 vintage....
  3. The Following User Says Thank You to mudski For This Useful Post:
    MB (4th April 2022)
  4. #33
    476 Post(s)
    Keep in mind too Phil, the GU's run and ECU. Not sure how you'd go with converting the loom so everything works as it should. Particularly the tacho and temp sensor. Your going to need the TD accelerator pedal too as the ZD and TB is electronic.
  5. #34
    198 Post(s)
    Thanks Mark, good to know. The loom is a $650 splice to run the dash, but Brunswick didnt mention the accelerator pedal assy.
  6. The Following User Says Thank You to PeeBee For This Useful Post:
    mudski (4th April 2022)
  7. #35
    198 Post(s)
    Rang Brunswick, they tear the electronics out of the pedal assy of the GU and convert it to a mechanical set up like in the GQ.
  8. #36
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    If you have a welder, here’s how I converted a ZD pedal with the TPS for the auto to a manual TD42 cable.
    I’ve since put the TPS on the pump but couldn’t be bothered removing the pedal to remove the ZD TPS.
    John
  9. The Following User Says Thank You to jff45 For This Useful Post:
    PeeBee (4th April 2022)
  10. #37
    198 Post(s)
    Thanks John,
    still tossing up whether to go GQ or GU, claim has been verified for payment it seems but insurance company yet to make contact regards the final options - so waiting waiting...
  11. The Following User Says Thank You to PeeBee For This Useful Post:
    jff45 (4th April 2022)
  12. #38
    198 Post(s)
    OK, another lemon to resolve. I want to keep the PTO for the hydraulic winch. The fitting of the GQ box into the GU is a pain due to clearances with the dash - does anyone know if the 3L manual GU box have a PTO function?
  13. #39
    198 Post(s)
    OK, final assessment in, repairable write off so, went thru as a repairable write off, keep the rego, no notification to Vicroads, bought the beast back for 13K, truckloads of balance to rebuild it, happy days.
  14. The Following 7 Users Say Thank You to PeeBee For This Useful Post:
    AB (5th April 2022), Cremulator (5th April 2022), jff45 (5th April 2022), MB (5th April 2022), mudski (5th April 2022), Touses (5th April 2022), Winnie (5th April 2022)
  15. #40
    That is a fantastic outcome, so glad for you Phil.
    So you are now hunting for a GQ cab?
