Page 1005 of 1057 FirstFirst ... 10031004100510061007 ... LastLast
Results 10,041 to 10,050 of 10564
  1. #10041
    Well Done Hodgestar
    Even matches your washer bottle cap
    You’re honestly going to love Optima’s
    I personally and many other mates face to face discussions are perplexed and have no idea where the McGoogle bad press comes from, can only assume insanely poor system designs because no one I know has experienced anything but bulletproof greatness
    Hodge (20th June 2021)
  3. #10042
    177 Post(s)
    Well Done Hodgestar
    Thanks Marko mate. When a new starter needed came up on the cards, it was a no brainer really. After seeing jff45 Johns setup and consulting legendary Mudrunner about fitting, it was a done deal.
    Extra caution is called for with the oil dipstick for it not to become a welding arc wand vs. the positive terminal with new battery height.
  4. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    Cremulator (20th June 2021), MB (20th June 2021), Mickhead (20th June 2021)
  5. #10043
    Feb 2011
    Shed
    45 Post(s)
    Nice new oil+filter+air filter= 2ltrs maybe of dirty black nasty sump oil on my concrete driveway.
    Some of you will know me n sump oil just don't get on
  6. The Following 3 Users Say Thank You to growler2058 For This Useful Post:
    Hodge (20th June 2021), MB (21st June 2021), threedogs (7th July 2021)
  7. #10044
    177 Post(s)
    Like growler.
    Changed oil and all filters. So freakin messy with the TD filters. Tidied up some electrics. Subby 'o clock now!
  8. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    growler2058 (20th June 2021), MB (21st June 2021)
  9. #10045
    Advanced Dasa's Avatar
    Aug 2019
    North central VIC
  10. The Following 7 Users Say Thank You to Dasa For This Useful Post:
    Cremulator (22nd June 2021), growler2058 (22nd June 2021), MB (21st June 2021), mudnut (21st June 2021), PeeBee (21st June 2021), rusty_nail (21st June 2021), Touses (22nd June 2021)
  11. #10046
    Aug 2019
    North central VIC
    Well that didn't go as planed.
  12. The Following 3 Users Say Thank You to Dasa For This Useful Post:
    growler2058 (30th June 2021), MB (30th June 2021), rusty_nail (30th June 2021)
  13. #10047
    Dec 2019
    Western Sydney, NSW.
    New Roof Rack fitted the past week.
    Removed the Old Rescue Basket (Ladder Rack) System, Rhino Basket and 150mm PVC Tube, and fitted a OCAM Alloy Flat Rack and two 100mm PVC Tubes in their place.
    Old Setup
    OCAM Replacement Rack "Less Solar Panel"
    Part way there
    Finished
    More practical storage solution now
    Grant
    Penrith Region
    Sydney NSW.
  14. The Following 2 Users Say Thank You to Grant209 For This Useful Post:
    MB (1st July 2021), mudnut (2nd July 2021)
  15. #10048
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Quote Originally Posted by Dasa View Post
    Although those circuit breakers are claimed to be waterproof, be warned - THEY ARE NOT. Water does get in around the shafts through the rubber membrane. At least that is my experience. And mine were only subjected to spray/splash and not immersion.
  16. The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
    Dasa (1st July 2021), MB (1st July 2021)
  17. #10049
    Aug 2019
    North central VIC
    Figured as much looking at it.
    So considering the battery location I guess the best option is auto reset breakers then paint it to seal it up.
  18. #10050
    198 Post(s)
    Installed some 90 deg hose bends on the rear engine cooling loop instead of the externally restrained wire hose formers, so now I have better flow than before - still have to install the kit i purchased from the US that is sized correctly apparently. Also installed a manual breather on the heater circuit so I can get rid of as much air as possible from the cooling circuit. Been a big day.
  19. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    MB (4th July 2021), mudnut (2nd July 2021), Rossco (2nd July 2021)
