Page 55 of 77 FirstFirst ... 5354555657 ... LastLast
Results 541 to 550 of 762
Thread: Jay see 1997 GU build up
  1. #541
    Jun 2018
    25 Post(s)
    I want to stop the power to my antenna. Reading online fist it was the purple one with a white strip, then blue, now I've cut 3 wires behind the plug and it still works.
    Does anyone know.
    Do you have an antenna control switch like this?
    The other place to look is on the back of the head unit there is an antenna control wire that triggers power to the antenna when the stereo is turned on.
  2. The Following User Says Thank You to Cremulator For This Useful Post:
    jay see (27th March 2021)
  3. #542
    Not any more. Using a AM/FM wip. That's why I don't want the antenna to work. The head unit is wired up through a switch and to the aux battery. Unplugging from the antenna will probably be best. Will see how I go tomorrow, soccer isn't till later in the afternoon..
  4. #543
    Remove the inner guard to access the antenna motor and unplug it from the motor.
  6. #544
    Getting a few to things done.
    Unplugged antenna, now to get the flare back on properly.
    Out with the old in with the new.
    and finally getting this roof console sorted. Continuing tomorrow.
  7. The Following 4 Users Say Thank You to jay see For This Useful Post:
    MB (8th April 2021), mudski (8th April 2021), Rossco (8th April 2021), rusty_nail (9th April 2021)
  8. #545
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jay see (8th April 2021), MB (8th April 2021)
  10. #546
    Yeah maybe, there's a bit of storage space in the console itself will see have it all goes.
  11. The Following User Says Thank You to jay see For This Useful Post:
    MB (10th April 2021)
  12. #547
    It's not completely finished, but it all works. Will need to find another radio surround, bloody wreckers wanted $70 I'll find something on marketplace.
  13. The Following 3 Users Say Thank You to jay see For This Useful Post:
    MB (10th April 2021), mudski (10th April 2021), Rossco (9th April 2021)
  14. #548
    I was at my folks place last night and was flicking through the local paper and saw ad for a tyre place in South Morang rang them up this morning and was quoted 1900, asked if they could do 1800 and if they had them in stock. Yes and yes.
    Did a few tight u turns and no robbing at all. This is will the wheel turned. It may be due to the 2 degree offset brush.
    One concern I had was in the wet, well today was a good day to test them, drove a bit harder into the corners around home and I'm impressed.
    Drivers side.
    Passenger side.
    Almost 5 years to the day and we'll over 100,000 km.
  15. The Following 5 Users Say Thank You to jay see For This Useful Post:
    Cremulator (25th June 2021), MB (26th June 2021), mudnut (25th June 2021), Rossco (26th June 2021), Touses (28th June 2021)
  16. #549
    Lockdown has given me some spare time, so I'm going to swap out my winch.
    Now my positive and negative cables from the battery are in good condition and neatly positioned in conduit to the front. Is there any reason why I need to change them? What should I use to give the ends a good clean?
  17. The Following User Says Thank You to jay see For This Useful Post:
    Hodge (7th August 2021)
  18. #550
    177 Post(s)
    What size are the existing cables ? Runva 13xp comes / needs 35mm2 .
    With the terminals just use something abrasive with some CRC , Lanolin etc...
