Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 142
Thread: Rear Winches - Lowering Down versus Hauling Dead Vehicles Up
  1. #61
    334 Post(s)
    Just in the shed trying to visualise it thanks mates, got me thinking again, is there any structural drawbacks on the OEM chassis back down the line?
    An element of chassis rail flexyness is possibly OEM designed in and hoping this wouldn’t lock them together too much?
    Only reason I mention is that I met a bloke before lockdown readying his ISUZU twuck for around Australia and he choose a full floating type tray <> chassis mount system to retain some flex he was trying to engineer in.
    Cheers!
    No more than the factory towbar does now mate.
  2. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (30th August 2020)
  3. #62
    483 Post(s)
    Double thanks Daz Mate
  4. #63
    334 Post(s)
    Mark, have a look at this design. This is what I believe addresses the forces and their directions - Vectors they are called. Its a serious structure, however it will do the job, and is what i would build myself. The integrity of the towbar is maintained and in fact is increased as it is now hard locked into the upper chassis member.Attachment 81895Attachment 81896Attachment 81897
    @MB @threedog if you can draw those fish plates to scale you could get them laser cut for sure mate.
  5. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  6. #64
    483 Post(s)
    Thanks Daz/John, great idea, Philstar did kindly ring on the Bat phone and suggest another mock-up firstly as we’ve noticed they would be most likely vertical plates, top to bottomish?
  7. #65
    483 Post(s)
    Must say, in theory, it could be a decent relatively easy commercial bolt on rear for utes that someone could make some backyard coin out of if their skills and time permitted
    Not too many nutters foresee the need for rear winches though :-)
  8. #66
    483 Post(s)
    Have diverted slightly off your awesome plan thanks @PeeBee Mate, a lockdown shed day finally made an agricultural looking start finally:-)
    Forgot I had this 200mm x 12mm plate & another 150mm x 10mm tucked away down at the yard.
    Added a couple of bracey triangles either side of the spool, may need more along the plate although I’m thinking it’s only a fairlead plate as the winch is bolted down on the 12mm beast below.
    Unfortunately had to sculpt out one of the triangles as the gearbox on the twin Sherpa is a larger diameter than the secondary motor side.
    Had enough for one day, next round will aim for the vertical “fish plates” to the chassis side holes & towbar below and a few speed holes for some sexyness to try and match her Millweld front
    Any do’s or dont’s for scrub truck safety before next round would be greatly appreciated please!!
  9. The Following 2 Users Say Thank You to MB For This Useful Post:
    MudRunnerTD (13th September 2020), Rossco (13th September 2020)
  10. #67
    Far out Markie that is chunky certainly aint gonna fall apart anytime soon lol. . . Nice work looks smick, get the old girl go'n shes had long enough rest and the mountains are call'n, hopefully can get there soon. . .
  11. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (13th September 2020), Winnie (13th September 2020)
  12. #68
    Looks good mark, top job. Don't overlook the load on the fairlead as it can be the primary reaction point of the pull. Adding the H/D fairlead assy will provide the support to a large degree
  14. #69
    483 Post(s)
    Cheers Gentlemen, was actually waiting to get properly flamed, it is quite fairly heavy this wacky contraption :-)
    Unfortunately the Tucker Truck still has a ways to go before next adventures, to name a few:
    #Seam busted rear main tank thanks to Champion Link TK :-)
    (Have a replacement ready but scratching my noggin on how to raise it 150mm ish for towbar rail walloping firstly next time)
    #Overheating 170amp GQ < > 6.5NA pimped up alternator again due to twin thermo fan frontal blasting.
    # A valve spring believed cracked from intense ‘run on’ experienced nearing a vertical pinch due to lack of lift pump air issue pressure as best as I can ascertain so far :-(
    Mountain Grubs will be back on the menu one day somewhere in 2021
  15. The Following User Says Thank You to MB For This Useful Post:
  16. #70
    Fab up a local area deflector to push the air away from the alternator, as discussed a fair while ago. Whats in the way of the tank going straight up or even displaced slightly? Why 150mm lift, how big was the ding? What about a simple bash plate out of ally, say 6mm?
  17. The Following User Says Thank You to PeeBee For This Useful Post:
