Page 11 of 14 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 140
Thread: TD42 - All Variants Aussie Water Thermostats
  1. #101
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Still got that 82deg @MB ? I'll send you some $ and give it a run if you do.
  2. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    MB (11th February 2020)
  3. #102
    Sorry TJ, just installed it last week mate in a work GQ. Can’t really tell what it’s doing yet as the old ute only has an OEM gauge at the moment.
  4. The Following User Says Thank You to MB For This Useful Post:
    0-TJ-0 (11th February 2020)
  5. #103
    Interesting thread MB. Nice one mate. So just fitted the 79c with the quikaz fan and hub. In have also just fitted the redarc guage you have which will give me insight into the water temps. I will have to get to k now tgis engine all over again now as this is a game changer. I think it 8s going to do my head in for a while though.
    MB (20th February 2020)
  7. #104
    Jan 2017
    South Australia
    11 Post(s)
    Is that the genuine 79deg stat your putting in or the dayco one from qikazz? I just ordered the dayco one from qikazz to give that a try. My temps aren't too bad most of the time just looking for a bit more stability and a scooch higher than the 74deg I saw it get down to on the down hill runs yesterday :/
  8. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    MudRunnerTD (17th February 2020)
  9. #105
    I've just put the Dayco t/stat in, as well as a new water pump, new radiator and the Qikazz fan/hub. Haven't driven on it yet, towing the van up to east Gippsland next weekend though so that will be a good test.
  10. #106
    Jan 2017
    South Australia
    11 Post(s)
    Let me know how it goes. I've just put the new hub and fan in and love it. Temp still slowly climbs on those big hills towing a 2 ton camper but much slower than it used to.. and drop it back to 3rd and than fan roars and temps drop. Brilliant. I'm happy with the overall cooling for now, I'd just like the default temps to be a bit higher and more stable, will stop me watching it so much haha.
  11. #107
    The dayco from quikazz. Now need to re learn the car with an accurate temp guage.
    0-TJ-0 (17th February 2020)
  13. #108
    Haven’t driven the old family GU faithful truckster for a little while now as was away working with the GQ almost as much loved kettle up north until this warming last weeks home. Scored a 39C ambient GU temp test day yesterday for a blast up our home test hill still on the Russian 88C winter TS as installed before.
    Finally managed to sneak a new 2019 record of 99C on this hill top once eased off the peddle with heatsoak and it blipped up there for a fleeting full open few seconds before back to old 76.5C TS same same too max of 98C summer found for us last year on the brand new then OEM radiator.
    Best I can nuffy understand from findings now is that regardless of purchased OEM thermostat settings the summer time ‘max’ temps in this wagon don’t seem to alter although the rest of the years warmer and down to seriously colder ambient temps hug so so much closer to healthier running temps of 88C + I smell and find much betterer :-)
    Really keen for anyone please to trial the OEM 82C (apparently Aussie manual spec) version to see if they can achieve similar‘stability’ instead of huge ‘fluctuations’ as what originally did scared me and these beloved donks we have!
    IMHO now: “It’s all in our cooling systems overall health”
    ~MB :-)
    Hey mate, you know how your a bloody rippa Bloke. Did you by chance fit the Black control box for your gauge is an easily accessible location? Yesterday during the install i accidentally closed the bloody drivers door while the loom was hanging out and destroyed the black plug that goes into the black box. damn it. Looking like it is not available and i need to make something work. I was at Gauge Works Geelong today hoping i could just buy a black plug and re-pin it but no joy. He said it may well be a common plug for the back of a stereo and suggesting i go to a wrecker and see if i can find something to suire and then re-pin it.
    I really need a couple of photos of it to be honest. and also very important, i need a good photo of the pin layout so i can re-pin it. I think it is a 4 wire but 8 pin connection.
    In fact anyone with a Redarc 3 way gauge like this i would appreciate any help you have. Will make a call to Redarc tomorrow but not sure they will help. Surely im not the first person to do this. To my astonishment the plug is made from a very brittle hard plastic rather than a Urethane Resin and has just disintegrated.
  14. #109
    Jun 2018
    25 Post(s)
    Is this what you need?
    You can download the manual from their site: https://www.redarc.com.au/egt-boost-...rature-display
    Just underneath the price is the PDF.
  15. The Following User Says Thank You to Cremulator For This Useful Post:
  16. #110
    Cheers mate. Yeah I have that manual in hard copy.
    No no have fully SMASHED this plug damn it. Beyond recognition. All the pins are safe but now out of casing. I need a new plug blank then re pin it.
