Results 1 to 5 of 5
Thread: Servicing the cooling system?
    May 2016
    lower west victoria
    30 Post(s)
    Planning a desert trip for later in the year.
    Vehicles's 5 years old done 140,000, sits on 88-89 mostly, seen it go up to 92 on a hot day.
    Anyway, what do I need to get done to have the cooling system serviced? Is it something I could I do with some new magical potion that's come out in the past 10 years or should I get it done by someone who knows what they're doing?
    Can a regular run of the mill mechanic do it or am I better off going to a radiator joint???
    With many thanks.
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    If you're talking full rad clean, block back flush et al, then a speccy rad dude is the go bro'.
    Although, a speccy rad dude put me onto a simple clean for the system that appears efficacious.
    Dishwasher cleaner. I shite thee not! Empty system, refill with clean water and supermarket dw cleaner. Run around as normal for a few days and empty again. Refill with water.
    Run around as normal for a bit more and empty again. Refill system with your usual water/coolant mix and off you go. Worked on my dear old gutlux. Moves quite a bit of gunge.
    Give it a shot, even if your system doesn't need looking at shouldn't harm it.
  3. The Following User Says Thank You to Touses For This Useful Post:
    0-TJ-0 (25th January 2019)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by Touses View Post
    Too much diswashing liquid.
  5. The Following 3 Users Say Thank You to 4bye4 For This Useful Post:
    GQtdauto (25th January 2019), mudnut (25th January 2019), Touses (25th January 2019)
    May 2016
    lower west victoria
    30 Post(s)
    Quote Originally Posted by 4bye4 View Post
    Take it out in th rain and it'd wash itself. Hmmm, intresting.
    Mar 2016
    Childers QLD
    22 Post(s)
    Reckon the head gasket has shat itself.
  8. The Following User Says Thank You to Touses For This Useful Post:
    4bye4 (25th January 2019)
