Results 1 to 5 of 5
Thread: 1988 4.2D GQ Headlight replacement
    Jan 2019
    Christchurch NZ
    Red face 1988 4.2D GQ Headlight replacement
    I am just about to upgrade my factory headlights to 7'' LED. Does anyone know how to retrofit these? Do I have to remove the whole grill to get access? Thanks
    IIRC the factory sealed beams are held in by 3 small screws and a retaining ring fully accessible from the front.. undo the screws and the retaining ring and light literally fall out... much easier with the grill out tho which takes all of a coupla minutes
    Dec 2017
    Yeah mate, you have to remove the grill. The screws for the headlights are covered by the grille. At least on my 89 model they are. Do you have sealed headlight units or the unsealed ones you can pull the light out of? Also, depending on the connector on your new LED lights, you may have to put on a new connector for the loom.
    There's also a spring on the bottom of the light housing holding them square.
    84 Post(s)
    If you haven't already obtained your LEDs, this guy is the one to talk to. http://www.nissanpatrol.com.au/forum...4-LED-Light-Co
    Zip over here and tell us a bit about yourself and your Patrol.
    http://www.nissanpatrol.com.au/forum...-Introductions
  5. #5
    Patrol Freak Sherro's Avatar
    Feb 2014
    Logan, QLD
    I'm running these from Stedi awesome light out put on hi and low beam.
    https://www.stedi.com.au/stedi-7-inc...headlight.html
