Page 844 of 1057 FirstFirst ... 842843844845846 ... LastLast
Results 8,431 to 8,440 of 10566
  1. #8431
    Fark me, wouldn't it be easier to wear two pairs of socks - that is one frightening project mark, god good luck.
    mudski (9th July 2018)
  3. #8432
    It will give me a chance to neaten up the wiring too. Plus get some sound deadening stuff on the firewall to try to muffle the intake noise from the intercooler.
    Rossco (10th July 2018)
  5. #8433
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    You sure that wasn't the A/C evap you are thinking of. As I have done mine before and that pretty much all I had to do. The heater box is located centre of the dash right above the transmission tunnel.
    Edit : See link for GUIV removal. Same as mine.
    http://www.nissanpatrol.com.au/forum...re-replacement
    As I recall, initially it was thought that the heater core was leaking and I went to an A/C - Radiator shop, where they removed all the under dash fan unit assy, and ducting up to the center console.
    They then removed a fin cored unit that sat up in behind the center console with two flange pipe connectors to it. Thought this was the heater core? At this stage this core was inspected and deemed to be serviceable and was reinstalled as it was a genuine unit. They then used an UV light and identified that the leak was A/C fluid and did a service on the A/C unit (maybe evap?), fitted new o-rings /seals and re-installed. Then they pressurized A/C unit and leak was still present and it was discovered that the o-rings at the firewall flange A/C joints were deformed solid and were not sealing.
    This is as I recall the event and am very prepared to be put on the right track as it is fairly unfamiliar territory and consider correction/guidance to be a part of good learning.. Thanks mate
  6. #8434
    Mark...
    We seriously need a selfie of your face when you read that...
    Right or wrong doesn't matter... just that instant in time as the brain processes the post should be priceless I reckon.
    Maybe even a good theme for the next months photo comp "The look on a persons face when..."
    Yeah I had a slight hint of rage flush through me when I first read it. Then I realised it was a/c evaporator that comes out easy. Hopefully tonight I'll get the lot out including the heater box.
    the evil twin (10th July 2018)
  8. #8435
    Oh god!
    Sent from my crapPhone using Tapatalk
  9. The Following 5 Users Say Thank You to mudski For This Useful Post:
    MB (10th July 2018), Rossco (10th July 2018), TPC (10th July 2018), warthog1 (10th July 2018), Yeti's Beast (10th July 2018)
  10. #8436
    There’s the bloody heater box! Right in the middle.
  12. #8437
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Your braver than me, I think I would of set it on fire.
    Now while you have it apart please have a look and tell me why my air control flaps rattle.
  13. The Following 2 Users Say Thank You to Yeti's Beast For This Useful Post:
    MudRunnerTD (11th July 2018), warthog1 (10th July 2018)
  14. #8438
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Mark, while it's open install a Cabin Filter. Just did mine and amazed what a load of crap/dust/leaves were in there.
    Quick vacuum and all good, here's the link and less than half the price of RYCO or REPCO
    http://www.brettstruck.com.au/Listin...0&searchType=2
    Jack
    2024 Isuzu MUX
  15. #8439
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Oh god!
    You are a brave, brave man!!
    You upgrading to a S4 dash whistle you’re at it? lol
  16. The Following User Says Thank You to Bacho86 For This Useful Post:
    mudski (10th July 2018)
  17. #8440
    Ooh got job Markie, just make sure you do up those hose clamps . . .
