10th June 2013, 11:06 AM
10th June 2013 11:06 AM
10th June 2013, 04:29 PM
Hardcore
You have busted the Clock Spring, id expect you will need to take some lube when you go to get prices on one (he-he)
I Taped mine together as soon as i took the steering wheel off, then removed the entire clock spring, i actually ended up pulling the clock spring apart to get sand out of it anyway, but didnt turn the two halfs so works no prob.
Thanks for posting your pics, i never removed the actual heater core from mine so its interesting to see, i still did as much remove/refit as yourself, so i know what you went through, im a bit concerned about your left overs, i didn't have any, but i took longer to to the job, interesting to hear if you have any rattles ?
Good on ya for having the guts to attack this anyway mate !
Let us know how much the clock spring ends up costing ?
10th June 2013, 05:48 PM
Travelling Podologist
Yikes! All I can say is that I hope I never need to fit a replacemet heater core!
Cuppa
A Nomadic Life (Blog)
10th June 2013, 06:49 PM
God have mercy ...
Good job though. And totally agree with Cuppa, I hope I never have to replace that my self.
On another note, do you leave coastally? The mainframe/skeleton has rust fragments, all over it. Or so it appears.
10th June 2013, 07:08 PM
Enjoying the trips
Macca
The Following User Says Thank You to macca For This Useful Post:
BigRAWesty (11th June 2013)
10th June 2013, 08:37 PM
the car is ex mine/rental had grey mud all through the chassis and grey dust all through the panels dunno where it gets it from though, but yes there is a bit of surface rust.
i took this to the local electronics repair shop hopefully he can solder it back together to save me buying a new one.
10th June 2013, 09:43 PM
Patrol Guru
bloody hell mate, what a journey, good onya, I am pretty good mechanically but I would never attempt that unless I had another set of eyes with me & then I probably never have the gonads to try anyway, your a legend mate, are you a Mecho?
2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
10th June 2013, 11:09 PM
believe it or not i'm a sparky by trade but my old man is a mechanic so i learnt a lot from him growing up. hopefully the TV repair man can fix the clock spring and i will be in business.
11th June 2013, 08:06 AM
Patrol Guru
still a champion effort bud, kudos to you
13th June 2013, 05:33 PM
yep, your a legend! good on you for having a go. if my heater core went I think I might have to wear more cloths.
3lt GU 111 Wagon 2 inch lift,3in Taipan exhaust, cross country intercooler,catch can,EGR blocked, dawes and needle valve,Pyro/boost gauge ARB lockers,steinbaurer chip, long range tank, s/s water tank, draws, warn winch, and other stuff.
