Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Keyless Entry
    Jan 2018
    Keyless Entry
    I got a 2003 GU lll ST patrol few weeks ago and wondering how i can find out if keyless entry is possible. Using the key on drivers door opens all the doors but would really like keyless entry via a remote.
    When i got the car it only came with 1 nissan key and another cut key
    CHEERS IN ADVANCE
    Plenty of aftermarket options available. My remote sorts the locks, alarm and immobilizer..... Made by Autowatch
    477 Post(s)
    Yours would more than likely have keyless entry from new. You just didnt get the remote as they always shit themselves and are worth their weight in gold for a new one, then it will just die again.
    The best way is to go after market. I did with mine, I bought the kit for less than the cost of one remote from Nissan.
    This link may help you....
    http://www.nissanpatrol.com.au/forum...der-20-minutes
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    As above. Cheap and works - as opposed to Nissan's expensive and fails.
    Nov 2010
    Getting a life...
    38 Post(s)
    Same. I went aftermarket after my car was broken into, but be aware you will also need to fit a diode if running a turbo timer with the alarm.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  6. #6
    Jan 2018
    Do i need to get a whole aftermarket set up or can i just get an aftermarket remote and get it programmed to factory set up?
    Sorry for the newbie questions
  7. #7
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    3 Post(s)
    I bought the central locking unit with 2 x remotes off ebay for under $20.
    Then all I needed was the master actuator for the driver door as mine didnt have it (key only central locking). Was about $10 from Jaycar.
    Unit came with instructions, easy to do yourself in a couple of hours if you are handy with a soldering iron and a screwdriver.
    This was in a 1998 GU ST.
    Cheers,
    Evo
  8. #8
    Jun 2013
    3 Post(s)
    This exact one.
    Cheers,
    Evo
  9. #9
    Jan 2018
    Havent used a soldering iron since high school haha
    Do you have to solder into existing wiring for this control box or how do you go about it? (again sorry for the newbie questions, im just starting out)
    CHEERS IN ADVANCE
  10. #10
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    I had a mobile service come out to program an after market remote to my stock system.
    He was in the driveway for 2 hours before he admitted defeat.
    The stock unit does not accept aftermarket remotes.
