Results 1 to 10 of 10
Thread: Soooo...my Odometer stopped ticking over...
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Evening critters and fellow Coily oilers...
    I have a 1990 TD42 GQ wagon. Its a new addition and the previous owner told me to look out for the random ODI stroke...The Odometer seems to stop here and there...Is it mechanical or electrickery?
    Cheers in advance for any clues...
    Just hit the trip counter reset....... Mine does it from time to time. I'm guessing there's something mechanical in there that gets stuck, probably a small cog
  3. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    GQtdauto (18th January 2018), MB TD42 (19th January 2018)
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Must be a common thing mine does the same thing .
  5. The Following User Says Thank You to GQtdauto For This Useful Post:
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Had my entire cluster sent off and repaired. Yes it is the nylon cogs that wear.
  7. The Following User Says Thank You to Touses For This Useful Post:
  8. #5
    Jan 2018
    Perth WA
    Cheers peeps...will give it a go.
  9. #6
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    i had that in my 90 gq, got a 2nd hand petrol one and swapped the bits over. got my old one sitting waiting for me to fix it.
  10. The Following 2 Users Say Thank You to garett For This Useful Post:
    dom14 (18th January 2018), MB TD42 (19th January 2018)
  11. #7
    Jan 2018
    Perth WA
    Gday garett... was there much work in DIY on the Cluster Ferk?
    Am looking to get a major service done after all the upgrades are in and was going to get Nissan to sort it then.
  12. #8
    Jan 2015
    north
    21 Post(s)
    i got someone to spin the sender and checked the signal at the dash with a mulitmeter, looked at some photos and discovered my speedo section was missing 2 components. (legs corroded is my guess). pulled both clusters apart swapped the speedo into my cluster and i'm good. took me maybe 1hr to swap and fit cluster. a couple screw drivers mulit meter to test, was pretty easy.
  13. The Following 2 Users Say Thank You to garett For This Useful Post:
    MB TD42 (20th January 2018), rusty_nail (19th January 2018)
  14. #9
    Legendary dom14's Avatar
    38 Post(s)
    The speedo & tacho on mine either stopped working or jumping intermittently few years back.
    I opened it up & cleaned the electrical connections with a tooth brush or piece of cloth or something and put it back.
    It has never given me trouble since then. I've been wondering whether trip meter and odometer issues might be the same(other than mechanical issues with wheels, etc). AFAIK, in mine, there are no mechanical cables that goes to the back of the instrument cluster for the trip and odometer.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  15. The Following User Says Thank You to dom14 For This Useful Post:
  16. #10
    Jan 2018
    Perth WA
    Cool mite get up the courage to pull it out n have a good look at the brains...found some old posts that talk about the worm gear on the motor slipping off...etc...
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
