Page 807 of 1057 FirstFirst ... 805806807808809 ... LastLast
Results 8,061 to 8,070 of 10562
  1. #8061
    Oops..........
  2. #8062
    Quote Originally Posted by Apollofish View Post
    Drove it 688km, another 529km tomorrow to reach our destination. Arkaroola Wilderness Sanctuary.
    Safe travels mate.
  3. The Following User Says Thank You to jay see For This Useful Post:
    jack (5th November 2017)
  4. #8063
    198 Post(s)
    Re-made the second alternator bracket so I could get better belt tension - works a treat now. Mounted the primary fuel strainer with heater under the truck. Removed the original second belt driven hydraulic pump for the front winch, free'd up some room for either the relocated ARB compressor or the endless air compressor - still dreaming up how this can work.
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (5th November 2017), MB (5th November 2017)
  6. #8064
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Where's the pics peebee ?
  7. #8065
    198 Post(s)
    OK, shamed into action!!! Couldn't get under the truck to show the actual strainer mount - too bloody late and truck is tucked up in bed in the garage.
  8. #8066
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Very noice , why twin alternators they make some pretty good upgraded units nowadays.
  9. #8067
    198 Post(s)
    I run a hyd winch on the front and a warn 15000lb on the rear via a big 200a/h battery, so the second unit is set up to pump the juice into the winch, plus my coffee machine! I run the driving light circuit off it as well as the LED bars run at 30V. The alternator supplied as standard with the Chev conversion is rated at 100a, and it struggles with voltage supply also - constant winge to brunswick diesels hasn't fixed the issue, so i went the second unit as it means I don't need to upgrade wiring for the existing circuits as well.
    There is a 170a unit avail, @MB has one fitted and it works well, but still requires some mods to fit. Lastly it also gives me some redundancy if one alternator fails - and yes it has happened to me on a trip, middle of winter, back of Omeo and miles from nowhere, very uncomfortable feeling, especially when some of the drive home would be in the dark.
  11. #8068
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Removed the plastic bumper cover and filled the dents. Sanded and primed it. Got up this morning and put 3 coats of base colour on, then buggered up the fourth and had to wait for it to dry, then sand and base coat again. Waited till it was dry this time then put on the gloss coat. Waited to dry then started to put it back on the car and scratched it. Took it off again, sanded, base coated and gloss coated. left it for tomorrow. Sitting down with Jim and ice now.
  12. The Following User Says Thank You to 4bye4 For This Useful Post:
  13. #8069
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Like the redundancy idea , the one in the GQ went at pineapple flat , driving home it got dark and car was starting to slow down as volts dropped off , lucky I had a good dual battery but only just made it home .
  14. The Following User Says Thank You to GQtdauto For This Useful Post:
    PeeBee (5th November 2017)
  15. #8070
    476 Post(s)
    Washed the Patrol after spending a magnificent weekend doing this...
    23244468_536321540051541_7652430130383911003_n.jpg23172498_536321550051540_4583497857335106506_n.jpg23316476_536321623384866_7081912265887713463_n.jpg
    With old mate @Sprock.
    And sat down each night to this...
    Thanks to Sprock, he had the fire covered before I could even set the swags up.
  16. The Following 14 Users Say Thank You to mudski For This Useful Post:
    AB (7th November 2017), Bacho86 (8th November 2017), BigJ (9th November 2017), Bush Ranger (8th November 2017), GQtdauto (9th November 2017), Hodge (8th November 2017), jay see (8th November 2017), MB (8th November 2017), my third 256 (8th November 2017), Rossco (8th November 2017), Touses (8th November 2017), TPC (9th November 2017), Winnie (8th November 2017), Yeti's Beast (8th November 2017)
