Results 1 to 6 of 6
Thread: Help. Rear tailshaft - which way round?
    176 Post(s)
    At a mates place with a hoist. Have discovered that the rear tailshaft on my leaf sprung GU ute is fitted with the spline (skinnier section of tailshaft) to the rear of the vehicle. The 'fatter' part of the tailshaft at the front, where it runs over the top of a crossmember. It sits above the cross member but a light (very light) mark around the circumference of the shaft suggests that at some point it has touched the cross member. Looking at the manuals is confusing, it seems that some models may have had the tailshaft fitted this way round, & some not.
    Can anyone tell me which way round the shaft should be on my vehicle and whether there would be any downside/issue with turning it around to increase clearance between shaft & crossmember. Would really appreciate replies tonight as it would be much easier to remove the shaft before we leave.
    2006 GU leaf sprung cab chassis
    84 Post(s)
    I've read that blokes with big lifts sometimes swap them for extra clearance. Dunno if that makes ingress of moisture into the spline a problem though. I suppose if the seal is good then no problem. Also dunno if affects the shaft balance or not.
    http://www.nissanpatrol.com.au/forum...rection-(rear)
    Yeah as above, factory is skinny @ diff end, but is common to turn it round so there's more clearance at the cross member. I'd put it that way, mines been like that with no dramas for ages. . .
    It is common practice to always have the join facing downhill. So if any moisture can get it it can drain out. If its the other way around moisture can get in but cant escape so the tube can fill up with moisture and dirt.
  5. #5
    Previous owner of my ute appears to have given the cross member there a light sledgehammer knock exactly where the tailshaft passes by there Cuppa.
  6. #6
    176 Post(s)
    Thanks, have decided to leave 'as is' for now as the hoist is unavailable until the OKA can be removed from it (needs to complete the fitting of a new Allison gearbox) so work would have to be done on sloping ground.... not ideal. I'll check it out again when we get back to Ballarat in a few weeks. The *very* light ring mark on the tailshaft probably occurred when the shaft was disconnected when the suspension/GVM upgrade was fitted.
    Going up to Barrington Tops today. May camp up there or continue across to Scone, depending upon the weather.
