31st August 2013, 10:04 PM
Tail Shaft direction (rear)
All,
I have a 2000 4.2TD coil cab, the spline joint on my rear tailshaft is closest to the rear diff, is this correct or should it be closest to the gearbox
G
31st August 2013 10:04 PM
31st August 2013, 10:10 PM
In all honesty I shouldn't matter, but mine is the same..
I think some of the boys running bigger lifts turn it around to to give more clearance over center cross member..
31st August 2013, 10:12 PM
You can run it either way but standard the small end is towards the back but when you start lifting your car above stock people swap them around the other way....
The Following User Says Thank You to Bloodyaussie For This Useful Post:
BigRAWesty (31st August 2013)
31st August 2013, 10:14 PM
Interesting, thanks Gents
31st August 2013, 10:20 PM
It faces that way for a reason. Generally they do have a seal but water will run down the shaft and drip off but if the other way around the water can get into the slip joint causing unwanted wear and tear. As its been stated flipping them is really only for clearance issues.
The Following 2 Users Say Thank You to nissannewby For This Useful Post:
BigRAWesty (31st August 2013), Bloodyaussie (31st August 2013)
31st August 2013, 10:35 PM
nissannewby
You sexy Matty!!!!!!!
The Following 2 Users Say Thank You to Bloodyaussie For This Useful Post:
BigRAWesty (1st September 2013), nissannewby (31st August 2013)
31st August 2013, 11:38 PM
1st September 2013, 12:33 AM
Hmmmm I want you Matt. Oh I mean you got it right mate but as long as you keep it full of grease you should be right
The Following User Says Thank You to Dhuck For This Useful Post:
nissannewby (1st September 2013)
