Page 413 of 570 FirstFirst ... 411412413414415 ... LastLast
Results 4,121 to 4,130 of 5698
  1. #4121
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Hey yeti thanks for the feedback! Can you tell me which wire / what colour the brake sense wire is? Cheers!
    Hi, the red wire from the controller goes to the green/yellow wire on the brake pedal switch. All the wires from the controller are labeled.
  2. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    Bacho86 (15th September 2017)
  3. #4122
    177 Post(s)
    Few Bunnings snags!!! Can't beat them......
  4. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Bush Ranger (16th September 2017), Yeti's Beast (16th September 2017)
  5. #4123
    It's the finer details that count. Especially when there's only 45 of them.
    When I brought my r8 it came with the compartment where the cup holder is, but no id build tag. Went to a hsv dealer and ordered a new one. Not bad for something that's 15 years old and they're still made in Clayton.
  6. #4124
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Also purchased a new Coleman EvenTemp 3 Burner Stove from tentworld to go along with the camper trailer!
    Attachment 73166
    https://www.tentworld.com.au/buy-sal...dle-grease-cup
    Love this stove same as mine
    Lucus30's 1999 GU ST TB45E
  7. #4125
    Attachment 73166
    That's a neat little cooker, never seen that before!
  8. #4126
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    What did you buy today
    Good to hear! I almost bought the hyper flame, but read a few bad reviews about them, so decided on this one. do you only use it on lpg or have you used the little Coleman gas bottle as well?
    It's a huge cooker lol - comfortably fits 2 x 32cm pans / pots on.
    Hopefully it'll be a winner!
  9. #4127
    Sep 2013
    16 Post(s)
    I use both, probably more the small cylinders.
    I'd recommend the carry bag you can fit 2 cylinders and the plate in it. The only downside is the plate is no where near as good as a cast iron plate, I also managed to bend my plate though not sure if it warped from the heat.
  10. The Following User Says Thank You to lucus30 For This Useful Post:
    Bacho86 (19th September 2017)
  11. #4128
    Dec 2015
    WA
    5 Post(s)
    A good idea is to trim the tails of your cable ties with flush cutters, or if you don't have a set use toe nail clippers, the sharp end can cut next time you reach in. Good to see you used a butt splice & not one of those dreaded scotch-locs, if you need to splice outside the cabin you can get butt splices with a built in heatshrink sleeve that is lined with hot melt glue (got mine from Altronics).
    Graham
  12. The Following User Says Thank You to GeeYou8 For This Useful Post:
    Yeti's Beast (22nd September 2017)
  13. #4129
    Nov 2010
    Getting a life...
    38 Post(s)
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  14. The Following 6 Users Say Thank You to katwoman For This Useful Post:
    Bush Ranger (21st September 2017), gubigfish (21st September 2017), jay see (21st September 2017), Maxhead (22nd September 2017), MB (21st September 2017), Touses (21st September 2017)
  15. #4130
    Nov 2010
    Getting a life...
    38 Post(s)
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  16. The Following 4 Users Say Thank You to katwoman For This Useful Post:
    Clunk (25th September 2017), Maxhead (22nd September 2017), MudRunnerTD (23rd September 2017), TPC (21st September 2017)
