Page 133 of 187 FirstFirst ... 131132133134135 ... LastLast
Results 1,321 to 1,330 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1321
    Got a bit done on the weekend. So everything is tacked up right.... So I need to unbolt everything and remove all the bar work off the car to get a heap of welding and grinding done ready for paint. I unbolted the rear bar and stupidly tried to remove it alone and broken the left darling wing off!! Grrrrrr. Cleaned it up and got Naomi to hold it while I tacked it again. Needless to say Naomi helped me unbolt everything.
    I also did some work to my winch. It's been in pieces but just need to put it together, might grab a Freespool blanking plate I reckon.
    Nice work..
    How did you go setting up the little mig in the end?
    Yeah pretty good mate. Playing around with the feed settings a little but the power setting has worked a treat. This bar work is a good job to tune it on as most of it's the same, a grinder fixes everything.
    Have concentrated on slowing it down when welding to the 16mm to really get a pool into the plate. Hopefully I have achieved some penetration.
  3. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (5th July 2016), threedogs (5th July 2016)
  4. #1323
    So I have been super slack with the GQ and all my bar work has sat in the back yard with surface rust all over the raw steal. I lost motivation.
    I'm back into it after a weekend in the highcountry in rossco's GQ and a huge recovery the following weekend got me itchy to get muddy.
    So found some motivation and for on the grinder and wire wheel and did the final clean up.
    I stripped my bullbar again as the water based paint I used didn't like the UV much and went a little cloudy. I hate oil paint to use but have bit the bullet and using a quality oil based enamel etch primer and now an Oil based enamel.
    3" foam roller I have found is by far the easiest way to paint bar work.
  5. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (27th June 2017), Clunk (28th June 2017), MB (27th June 2017), Rossco (27th June 2017)
  6. #1324
    Good to see the motivation back mate and keen to see the scrub bars on, mine are still sitting in the shed damn it!
    No slip joint on the scrubs to sliders?
  7. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (27th June 2017)
  8. #1325
    Nah I fitted the Camberg joined close to the bullbar and you can see the tail on the rear of the sliders for the rear scrubs.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    AB (27th June 2017)
  10. #1326
    Whoh nice one, good to see the motivation rolling again. Yeah the GQs are a beast enjoying the rebuild heaps but hanging to get mine going again. . .
    Bar work looks smick as ☺
  11. The Following User Says Thank You to Rossco For This Useful Post:
  12. #1327
    Nice work Daz, time to get this beast on the road!
  13. The Following User Says Thank You to Winnie For This Useful Post:
  14. #1328
    Shit Hot Dazz, keep pushing forward hard mate!
  15. The Following User Says Thank You to MB For This Useful Post:
  16. #1329
    Nice work there Darren. You make the front bar too?
  17. The Following User Says Thank You to mudski For This Useful Post:
  18. #1330
    Nah the front bar is a "FAT" bar. Unfortunately the guy that made them went mining and stopped making them. Arguably the best comp bar made. Everyone else has been trying to make them as good ever since. Great bar.
  19. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    mudski (27th June 2017)
