Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 115
Thread: PWM or MPPT.
  1. #61
    Ballarat, Vic
    177 Post(s)
    Question how close to the battery do these things have to be, 600mm-900mm
    enough??? no eye dear lol
    As close as possible & practical. However NOT inside a small enclosed space WITH the battery where gas could build up. Although most unlikely you should never risk putting ANY electrical equipment which has a potential to create a spark in an evironment which could possibly become explosive. With AGM/Gel batteries the risk is minimal, but they can gas in some situations. The risk is far higher with wet batteries.
    Wet batteries should never be inside the vehicle.
  2. #62
    Thanks Cuppa.
    That makes sense...
  3. #63
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Quote Originally Posted by Throbbinhood View Post
    There's a handy excel spreadsheet on the myswag forum that helps calculate expected amp usage for various things (fridges/lights etc), then you plugin your batteries/panel sizing etc and will give you estimate usage rates, how many days you'll get out of x etc. Its good kit.
    You wouldn't have the link by chance?
  4. #64
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    where would you mount it, Im thinking of mounting my mppt somewhere
    inside the bullbar on the AUX battery side,
    I mounted mine above the glove box, out of sight and can be accessed easily if needed. My aux batt is under bonnet so as close as I could while remaining out of elements and engine heat. If I had a rear battery which may happen one day, I would relocate to the cargo barrier.
  5. The Following 3 Users Say Thank You to sooty_10 For This Useful Post:
    Hodge (15th April 2017), jay see (15th April 2017), threedogs (15th April 2017)
  6. #65
    Jul 2014
    6 Post(s)
    Quote Originally Posted by Covo71 View Post
    Here is the link. http://symon.id.au/symon/myswag/Symon%20Solar.xlsx
    Please note this is an excel spread sheet.
    Thanks to Symon from the Myswag forum for the spreadsheet, hopefully doesn't mind me sharing it here.
  7. The Following 3 Users Say Thank You to Throbbinhood For This Useful Post:
    Clunk (24th April 2017), Covo71 (22nd April 2017), threedogs (18th April 2017)
  8. #66
    I already have some decent sized cable coming from
    the Aux battery to the bullbar a run of about 500mm,
    terminating at a 50amp anderson plug. I should be
    able to wire my weather proof MPPT reg up inside the grill
    I think. Also need to change the 50 amp anderson to a fully fitted job
  9. The Following User Says Thank You to threedogs For This Useful Post:
    GQtdauto (18th April 2017)
  10. #67
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Still playing with the setup on the GQ , might pee off the 20 watt and just use the 100 watt for now .
    Just have to solve the age old question of where to put the reg without running the wires too far although it looks like yours is sorted .
    Thinking that the trip to the corner country next month will let me know the problems with the system if any and then I can fix it before next years 6 month trip hopefully to the cape .
    Fancy looking Anderson plug you have there .
  11. #68
    Like you I have a small 10 watt panel, Im thinking that would be OK to hook up to
    start battery to keep it "busy",
    Must also figure out how to have a solar outlet at the back I have that cig,merit and guage
    for the small cut out, this would come in handy depending on the camp site,,
    position of the sun etc, somehow I need to get my Patrol fixed first.lol
  12. #69
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yeah everyone's rig is setup slightly different TD , and we all have our own ideas sometimes right sometimes wrong .
    Still haven't finished my setup I'm busy doing other stuff and charging up a mates dead ride on mower battery which has gone from 5 volt and .1 amp to 11.65 volt and .78 amp after one full day on the GQ 100 watt solar and holding .
    So will keep it up for a couple more days and see if it restores the battery , I notice the equalisation charge is pulsing 16.5 volt into it to try and shock it into life .
  13. The Following User Says Thank You to GQtdauto For This Useful Post:
    threedogs (19th April 2017)
  14. #70
    Well just doing a quick hunt and found the VE 75/15 with Bluetooth dongle for $195.
    Dongle is $65 alone so about a $20 saving..
    Look at this on eBay http://www.ebay.com.au/itm/391646943763
    Sent from my SM-G800Y using Tapatalk
  15. The Following User Says Thank You to BigRAWesty For This Useful Post:
    GQtdauto (24th April 2017)
