Page 365 of 570 FirstFirst ... 363364365366367 ... LastLast
Results 3,641 to 3,650 of 5693
  1. #3641
    84 Post(s)
    My 2nd hand Aldi winch is still going as well, but the brake mechanism is useless.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    GQtdauto (13th April 2017)
  3. #3642
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Second hand and still going !
  4. #3643
    84 Post(s)
    It was full of rusty water when I stripped it. After a long tedious clean out, I ran a bead of silicon around internal vertical faces of both the motor end and the gearbox end. and I then fitted a layer of glad wrap on the silicon and assembled the unit loosely and let it set. After a day I removed the wrap and tightened the fasteners. With a smear of water proof grease on each end of the drum it runs smoothly. I have had the unit under three feet of water and not a drop entered.
  5. #3644
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Mines been in for a drink quite a few times , perhaps a bit of maintenance might be useful , either that or next time they come up at Aldi I could buy a new one and replace the old one , maybe keep it for spares .
  6. #3645
    84 Post(s)
    Are they still selling them?
  7. #3646
    177 Post(s)
    They come up for sale once or twice a year. And they sell out very quickly .
    mudnut (13th April 2017)
  9. #3647
    84 Post(s)
    I think I will upgrade. The first stage of the gearing runs on aluminium teeth moulded into the casing. I have seen some of more expensive units have all steel gearing and stronger braking mechs. My unit's brake is only anchored with a couple of grub screws.
  10. #3648
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Only problem I've ever had was I left the hand controller on wireless mode and the battery in the hand controller went flat which meant I couldn't use the winch in either mode until the battery was replaced .
    I now switch to wired mode until I need to use it so if battery does go flat again at least I can use it with the wires plugged in in .
  11. #3649
    Do you really think a remote [wireless] hand control is worth it.
    More of a gimmick IMO as there is too much delay when compared to the
    OE controller, which is slow in its own right..........
    When my patrol is going Ill be fitting a pressurizing kit to it only needs
    a couple of pounds of pressure to be workable.....
    I have a spare 10,00lb winch here I will re-co at some stage
  12. The Following User Says Thank You to threedogs For This Useful Post:
    GQtdauto (14th April 2017)
  13. #3650
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Best thing about the winch is the wireless hand control TD , mine is starting to get a delay but it might be time for a new battery .
