Page 730 of 1057 FirstFirst ... 728729730731732 ... LastLast
Results 7,291 to 7,300 of 10566
  1. #7291
    Installed step-up transformer to drive the LED lightbars at 28V, rated at 40a - turned it on and burnt the retinas out of my eyeballs - very very bright! No, I don't have before and after shots, but turned on with 28V in half bright sunlight the garage insides simply washed out to white. Will see how they last and what effect they have on other road users or when using in the bush - probably overkill. in close quarters.
    juzzs8 (9th March 2017)
  3. #7292
    84 Post(s)
    Felt a bit of "chatter" in the steering directly after having a wheel alignment. I adjusted the steering box grub screw and all is well. Strange that it needed doing though.
  4. #7293
    Quote Originally Posted by PBBIZ2 View Post
    This sounds like a decent mod, got any more info about it, very interested
    seeing most light bars are what 9-30volts??
  5. #7294
    http://www.ebay.com.au/itm/152215332...%3AMEBIDX%3AIT
    This one is 30A, but you can get another for 40a, which I did. Simple to wire, just need to find somewhere to fit it - IP68, so a dunking won't hurt it. It does 'buzz though' but you can only hear that with the bonnet up.
  6. #7295
    drove it to the panel beaters
  7. #7296
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Betcha wish you drove it home from the panel beaters.
  8. #7297
    Quote Originally Posted by 4bye4 View Post
    only because I don't like relying on others for lifts to and from work
  9. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    4bye4 (20th February 2017), juzzs8 (9th March 2017)
  10. #7298
    Putting finishing touches to Titan draws , fridge plug was working it's way out so now Anderson plug .
    Current job is installing third battery which will go beside fridge on passenger side so will have main crank plus two 110 amp gel cell batteries in car and two 105? Amp in camper trailer , fridge in car 45 ltr will be used as a freezer , 60 ltr ARB in camper as a drinks and food fridge .
    Just finished the cooling fan to back of fridge mounting still have to put in the switch and the fridge switch and get proper tie downs .
    Setting up for desert trip in may / June .
    Attachment 70815Attachment 70816Attachment 70817
    Attachment 70818Attachment 70819
    GQTD, do you have any details on the cooling fan you have used? I have installed a temperature controlled unit directly above the engel that turns on when the air temp gets to 36Deg and off at 30 - its fully automatic but a bit bulky - have tried a number of the 'computer style' cooling fans but they don't last - yours looks a lot heavy duty than the ones I have used.
  12. #7299
    I used a small computer style fan that blows air on the motor everytime it cycles.
    very cheap and easy as ti fit and wire, Huge bang for buck outcome imo
    Been in for over 20yrs and still going strong
  13. #7300
    Got to be happy [sort of] about that
