Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: ARB Bullbar Fog Light switches
    Where is the factory fog light switch located? I've never seen one??
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MudRunnerTD (11th February 2017)
  3. #12
    Ha! Welcome to the late comers! That's actually the point of the thread mate! I have No Idea!
  4. #13
    On the stalk..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MudRunnerTD (12th February 2017)
  6. #14
    Expert clubbyr8's Avatar
    Penrith, NSW
    In my 2010 GU, the fog light switch is integrated into the headlight switch but no sure when that was introduced....
    fog
    by Bob Howard, on Flickr
    GROOVY GUVII
  7. The Following User Says Thank You to clubbyr8 For This Useful Post:
  8. #15
    Dec 2015
    WA
    5 Post(s)
    Im not sure how they should be fitted from factory or ARB but DRLs can be wired in via ignition so they're on when the car is on or via a switch.
    I thought that DRLs had to turn off when the headlights were on, so ignition to one side of the relay coil, other side of relay coil via a diode to headlight +ve, or x2 diodes for low & high beam +ve.
    Graham
  9. The Following User Says Thank You to GeeYou8 For This Useful Post:
    Winnie (12th February 2017)
  10. #16
    Penrith, NSW
    For my DRL's I used a 5 pole relay. So the DRL's work when the relay is not energised (and the ignition is turned on). The relay operates when the headlights turn on and consequently, the DRL's are turned off. The DRL's still work when the parking lights are on....
    GROOVY GUVII
  11. The Following 3 Users Say Thank You to clubbyr8 For This Useful Post:
    BigRAWesty (12th February 2017), MudRunnerTD (12th February 2017), Winnie (12th February 2017)
  12. #17
    Quote Originally Posted by clubbyr8 View Post
    fog
    Can't say I've noticed on mine..
    We don't have them fitted though.
    Penrith, NSW
    GROOVY GUVII
  14. #19
    476 Post(s)
    Quote Originally Posted by GeeYou8 View Post
    Graham
    Maybe so, I was just saying how it can be wired...
  15. #20
    maybe those spare fog light plugs only work with
    the Ti or GR and not hooked up on the lesser models?? lol
    @GeeYou8 is right the DRL should turn off when headlights are on
