Page 48 of 136 FirstFirst ... 4647484950 ... LastLast
Results 471 to 480 of 1356
Thread: All Things Chev
  1. #471
    Nov 2010
    Getting a life...
    38 Post(s)
    Really?
    Where are the pics?
    It doesn thave something like a turbo 350/400?
    Yeah. A 400. He had it at ABs last party.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  2. #472
    North brissy
    Thats the transmission. I was talking about a turbocharger or even 2 being a v8
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    Rossco (18th January 2017)
  4. #473
    Nov 2010
    Getting a life...
    38 Post(s)
    Oh. I dunno. I just drive it.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. #474
    Nov 2010
    Getting a life...
    38 Post(s)
    I don't have pics of engine bay. I'll do it tomorrow.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  6. #475
    Nov 2010
    Getting a life...
    38 Post(s)
    It's the ute with the V8
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  7. The Following 2 Users Say Thank You to katwoman For This Useful Post:
    gubigfish (21st January 2017), MB (19th January 2017)
  8. #476
    Mounted 200amp aux alternator onto the chev today. Was trying to fit the endless air in as well however I have to now move the difflock compressor to fit the endless air in - just wasn't up to it. The endless air belt drive will be off the aux alternator pulley, and it will be mounted below the aux alternator. Pics attached. Took a couple of nights scribbling a plan and then getting the materials. took about 7 hrs to fabricate and install - probably had the bracket on and off the car 20 times during the process. Will wire it tomorrow, direct to the 3rd battery in the rear, that drives the rear winch. Its a 200a/h/1300cca unit - huge.DSC01733.JPGDSC01734.JPGDSC01735.JPG
  9. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (22nd January 2017), rainsey (27th January 2017)
  10. #477
    May 2011
    7 Post(s)
    On my Brunswick installed 6.5 the interface between the Intercooler and the inlet manifold is a cone looking tube with a kink in the end to accomodate the intercooler hose.
    I am toying with putting in a larger intercooler but the height of this inlet is too high.
    Does anyone know of a inlet connector that is lower than that which Brunswick use and will permit not only a larger intercooler but also a fan to be used?
    Kindest regards
    Rainsey
    Sent from my iPad using Tapatalk HD
  11. #478
    Quote Originally Posted by rainsey View Post
    Kindest regards
    Rainsey
    Rainsey can you drop a photo of what you have? My engine is NA so totally different setup. My years in piping config may lead to a simple solution.
  12. The Following User Says Thank You to PeeBee For This Useful Post:
  13. #479
    May 2011
    7 Post(s)
    Incoming
  14. #480
    Incoming
    If you are talking about the black fitting, this can be made to any height and shape you need by a good sheetmetal worker - its a simple transition cone. I think BD have probably gone for a standard element, but this could be reduced in height to say the diameter of the inlet pipe to the manifold.
  15. The Following User Says Thank You to PeeBee For This Useful Post:
    rainsey (28th January 2017)
