Page 162 of 220 FirstFirst ... 160161162163164 ... LastLast
Results 1,611 to 1,620 of 2192
Thread: AB's new GQ is finally here
  1. #1611
    thats feckin funny
  2. The Following User Says Thank You to Avo For This Useful Post:
    Stropp (18th October 2016)
  3. #1612
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Is the donk in yet? LOL
    ________________________
    ______ 2017 D-Max _______
  4. #1613
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    In discussions mate
    Picked up the engine today!!
    Going to be a bit of stuffing around to get this to work but all good.
    It's a Ti engine so there's a little indentation where the tacho sensor goes so mine is no good.
    I need to decide what to with the vac pump hole under the injector pump, I guess I can just make a plate up and block that hole.
    Make up a new oil feed line for turbo
    Old gaskets from my GQ are fun.
    I need to get this new flywheel lightened 1.5-2kg and balanced with the clutch yet again.
    Need another spigot bush
    Oil drain.
    Remove old gaskets from new engine.
    Fix 3rd injector that we had issues with on my old engine.
    New belts, gaskets, oil cooler kit, etc
    New dipstick
    Oil and filters
    Check clutch alignment holes
    Yeah different flywheel mate, larger crank, etc.
    Wow man its all happening.
    Good luck with the Turbo, as yet don't understand what happened but if it caused the problem....
    Also had no idea how different the engines are, bit of a fiddle to make it all connect, fit and line up. You sound like having a challenge in front of you, best of luck.
    Anyway it is good to read you are getting somewhere with it all, good luck mate.
    Macca
  5. The Following 2 Users Say Thank You to macca For This Useful Post:
    AB (18th October 2016), Rossco (18th October 2016)
  6. #1614
    Dropped off clutch and flywheel for balancing and lightening at Duggan.
  7. The Following 4 Users Say Thank You to AB For This Useful Post:
    Chappy (28th October 2016), Stropp (18th October 2016), Touses (18th October 2016), Winnie (18th October 2016)
  8. #1615
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Clutch n wheel off other wouldn't fit or damaged?
    Edit:- Sorry, read back a coupla posts. Understand now!
  9. #1616
    Very time poor during the week but managed to get both 18th century gaskets off and clean the oil cooler and water pump.
    Also noticed the dip stick compared to mine is a lot longer with longer min max line then worked out the td42t holds more oil than the silver top.
  10. #1617
    Recon you'll get all the bits ready for the weekend?
  11. #1618
    No chance mate. I tried to work out all the bits I need but there's some things I've already missed and things will crop up.
    I need to get some bits on to work out what else I need like correct lengths of line for the turbo, etc.
    I was hoping to get everything done so we can go somewhere local for Melb cup but it looks like next weekend will be the weekend of getting things on and working out the final bits for final install Melb cup.
    I'll see how I go though. Mums back from hospital so I need to spend time with her too.
    We'll get there, I don't want to rush either. I can't find torque settings for the pulley on the water pump???
  12. The Following 5 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (19th October 2016), Plasnart (18th October 2016), Rossco (18th October 2016), Winnie (18th October 2016), Woof (18th October 2016)
  13. #1619
    Don't bloody rush it! Get it right, we can trash your place whenever it happens!!
    Gong him Red!!
  14. The Following 4 Users Say Thank You to Plasnart For This Useful Post:
    AB (18th October 2016), Kimbo63 (19th October 2016), Maxhead (18th October 2016), Rossco (18th October 2016)
  15. #1620
    Yeah nice be good to get it going but no point rushing may as well do it premo. Won't be long tho can't wait. .
  16. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    AB (18th October 2016), Stropp (18th October 2016)
