Page 130 of 177 FirstFirst ... 128129130131132 ... LastLast
Results 1,291 to 1,300 of 1768
Thread: Ask all your general ( none related forum ) computer questions here
  1. #1291
    Expert UncleFrosty's Avatar
    Aug 2016
    Goldfields WA
    USB ports on laptops are probably incorporated into the motherboard, so you may have to brace yourself for the bad news that it's not fixable (depending on how steady the Tech's hand is!)
    If for some reason the USB is separate to the motherboard inside the case then much more likely to be able to fix.
    Are the ports loose or just stopped working?
    What brand/model? I'll do some Dr Google-ing if I get a chance...
  2. #1292
    Aug 2016
    Goldfields WA
    Re: SD card Bluetooth adapter...
    Can't say I know of anything like this, but someone may've made one. I'll DrGoogle as well...
  3. #1293
    Do you use a wi-fi network at home?
    I use airdroid to transfer files through the wifi network from my PC to my mobile.
  4. #1294
    Aug 2016
    Goldfields WA
    Ha! You learn something every day...
    Toshiba make an SD card Bluetooth adapter. Found it on e-bay, but Telstra mobile system playing silly buggers up here and cut my data connection... 😠
    Believe I searched for "SD Bluetooth card". Came in at about $40-$50. (USD???)
  5. #1295
    Told you I know zip about all this, I might go see how much to fix USB ports
    The newer laptop had bluetooth so it was easy to put pictures here and transfer
    them from device to device.
    So is there are sort of SD card thingy I can use as Bluetooth I have a disc drive on this lappy
    so you've only got one usb port on your lappy then?
    http://www.ebay.com/bhp/bluetooth-sd-card
  6. #1296
    Aug 2016
    Goldfields WA
    Cheers for posting the link Clunk.
  7. The Following User Says Thank You to UncleFrosty For This Useful Post:
    Clunk (6th September 2016)
  8. #1297
    After to bloody long my warranty has come through finally. Will hopefully see the new graphics card this week. They have apparently upgraded us to a better one. I feel that this is for the stuff around and to compensate us as the new one is listed at more than double the price of the last one.
  9. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Hodge (7th September 2016), rusty_nail (7th September 2016)
  10. #1298
    What card are they giving you?
  11. #1299
    Finally, I can't believe it's taken this long. That's an absolute joke
    Sent from my BV6000 using Tapatalk
  12. #1300
    And it's all your fault ....... should have just punched him in the balls and been done with it
  13. The Following User Says Thank You to Clunk For This Useful Post:
    rusty_nail (8th September 2016)
