Page 297 of 570 FirstFirst ... 295296297298299 ... LastLast
Results 2,961 to 2,970 of 5693
  1. #2961
    Alternatively, leave the Airlocker compressor in play and just run an airline from your new compressor to an ARB Solenoid to isolate it and it can then be used as a back up if needed. Your Airlockers will function no better with the bigger compressor.
  2. #2962
    yeah nah its right now. The locker switch just turns on a Solenoid to activate your airlocker. I assume your running the ARB loom for the diff locker compressor? if so and you are happy to remove the locker compressor? then literally just remove the locker compressor and install the new one and plug it back in... Nothing to do, nothing to change.
    The first switch turns on the compressor. The airlock switch does nothing to the compressor other than use air and initiate the low pressure switch to activate the compressor again. The ARB loom powers up the air locker switch Pin2 from the Pin3 on the Compressor switch but this is irrelevant to you.
    The only thing you may need to alter is the supply size tot he new compressor and the size of the relay to activate it so only the Battery to Compressor side of the loom, the rest stays the same.
    Yeah as I thought about it more. Its all the same. Apart from the actual wiring loom. The new one has some really heavy wire and different plugs. I'll work it out...
    MudRunnerTD (18th August 2016)
  4. #2963
    Nice score. Nothing to figure out mate. It has a pressure switch and cuts in and out off that. The loom turns it on. When you use the locker the solenoid opens and trips the pressure switch. Just add your pump up line in with female nittos and the pressure switch will still operate. The airline becomes storage.
    Cheers Daz.
    As it stands now with my current compressor. I have two switches, one to turn the compressor on, it will only run though if its below the set pressure switch. And then theres the actual locker switch.
    So I'm assuming, well hoping, with the new loom, I can do a third function of just soley running the compressor.
    so in the quote from me above i talk about your pump up air lines. basically its a closed pneumatic circuit. Your compressor is switched from the pressure switch as a safety and will cut in and out according to the pressure in the lines. If you only have airlocks then when you first turn the compressor on it has to pressurise the locker air lines to the solenoids then the pressure switch cuts out the compressor and the airlines are charged with 120psi. You flick on the airlock and the solenoid opens to send air to the locker to activate it and the pressure drops in the lines and the compressor starts because the low pressure switch activates. happy days.
    If you now run air lines to the engine bay, the back and each side and fit a female Nitto type plug that shuts off when not connected that line will now need to pressurise when you first turn the compressor on. when it holds 120psi the compressor will cut off. If you plug in an airless to pump up your tyres the compressor will start automatically as it now lost pressure. Your just adding more lines, more air. the circuit doesn't care if its an airlocker or a tyre.
    Hope that helps mate.
    mudski (18th August 2016)
  6. #2964
    Yeah it does. As I thought about it more it made sense. I just had it worked out in my head a different way. Just the wiring for this compressor is so different. I'll wait until I get my car back then worry about it.
    Yeah I know that, it mainly for just airing up. My portable jobbie is to big to be portable. This will kicks it rsss in the psi department anyway.
  7. #2965
    Jul 2013
    Bought an Engel Batman 150 dual battery system to day for $100.
  8. #2966
    Quote Originally Posted by Bush Ranger View Post
    PM sent regarding winch
    Bush Ranger (20th August 2016)
  10. #2967
    BiPolar Fool BSRT.Beast's Avatar
    Apr 2015
    Keysborough
    4 Post(s)
    Bought a Travel Buddy Oven and a Evakool Tmx35 fridge ........... now I'm dirt poor and still looking for someone to install my lokka
  11. #2968
    Jul 2013
    Thanks for that 3D.
  12. #2969
    Patrol God Stropp's Avatar
    38 Post(s)
    Scored from bcf $99 each good value, the guy called the knife and saw set the midland murder kit ?
  13. The Following 3 Users Say Thank You to Stropp For This Useful Post:
    Kimbo63 (21st August 2016), oncedisturbed (20th August 2016), Woof (21st August 2016)
  14. #2970
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    You could put them to use at the Wa massacre I mean meet lol
  15. The Following 2 Users Say Thank You to Kimbo63 For This Useful Post:
    Stropp (21st August 2016), Woof (21st August 2016)
