Results 21 to 30 of 33
Thread: Plastic Jerrys on the Roof?
    Perth WA, NOR
    Sub tank
    I've only seen about 50 odd litre after market sub tanks, but I've not looked too hard. I wonder how low they sit??
    Is the sub tank the side tank or the back tank?
    A few places make/sell them. Brown davis, 4wd systems, Long ranger, ARB have plastic ones on the way etc
    The subs are around 70-80L and sit on the side and don't hang too low.
    http://thelongranger.com.au/nissan/patrol/gu/diesel
    Patrol GU8, Manual, snorkel, steel bull bar, Simpson Ed
  2. The Following User Says Thank You to schanmala For This Useful Post:
    jay see (16th August 2016)
  3. #22
    Make a box which bolts to the roof rack. And then a simple tie down Threw the handles..
    They won't move..
    This is my Outback Touring Roof load.
    My rack is full length Alloy
    There is an OzTent RV5 on the right side. A roof top bag with spare Tyre, parts, exhaust jack and some tools at the front.
    I made this box out of 19mm pine cause I had it. It's glued and screwed and should paint it but never have. The base spans full width to carry the load across the Alloy rack. Underneath the rack is some 70x19 spanning too and screwed up through the rack to clamp in position. She ain't going anywhere!!!
    Ratchet strap through the handle and it's solid and no vibration at all.
    It works bloody well for 60lts. Of fuel.
  5. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    10G (17th August 2016), BigRAWesty (16th August 2016), caveman21 (17th August 2016)
  6. #24
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    My sub is a Brown Davis, as others mentioned. All up it's 76l. Doesn't sit low at all. For touring use it'd be hard to find somewhere gnarly enough to see it damaged. I had it installed as part of a big fit-out at TJM so got a good price. But yes they're around $1000 fitted. In QLD you need a blue label once you change fuel tank size too.
    In reality I didn't need to put a Jerry on the roof, I think it was mostly for psychological reasons only!
    Thanks Boinzo, that's good to know.
    I see in your signature you have an 80L sub tank. Got any details on that??
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
  7. The Following User Says Thank You to Boinzo For This Useful Post:
  8. #25
    May 2016
    lower west victoria
    30 Post(s)
    Hey thanks so much for this reply MudRunnerTD, I really appreciate you taking the time to post the photos and the write up, that's a great help.
    You do what I'm planning on doing, but I was only thinking of 2 jerrys, maybe I'll go with 3 now.
    You've all been fantastically helpful, thanks heaps.
  9. #26
    Heres a TJM jerry holder dont worry about the other bits they were for a job I was doing.
    Plus I have a Brown Davis 75 ltr sub tank and love it, Gives me about 1000-1200 range I would think
    I would opt for either a main long range /sub or both in favour of carrying jerrys on the roof but thats
    just me I suppose, Simmo may be different kettle of fish
  10. #27
    May 2016
    lower west victoria
    30 Post(s)
    In the long run I will upgrade one of my tanks, but ATM I have a squillion things I need to get before a trip coming up in a month.
    I reckon someone smarter than me should make a double jerry can holder that bolts onto the rear of the Patrol somehow. That pic above looks like you've adapted the holder to bolt onto where the spare wheel sits on the rear door.
  11. #28
    You got it in one it was a favour for one of the guys at
    TJM it was meant to fit the back door of a landrover 110
    Its only 25kg approx so well under the weight of a spare
    rim/tyre combo
    @MudRunnerTD whats in the white screw top plastic tub???
  12. #29
    rim/tyre combo
    Magic.
    It's empty. I used it as a washing machine and worked great in the desert. Put your smaller in it with some washing powder and 2 or 3lts of water and drive all day and wringe out when you get to camp. Washing done. The agi movement all day washes everything really well. It was empty space on the roof so was perfect.
  13. #30
    I have a 145lt LRA tank in the rear of the GUIV and a 30lt sub tank. My Madigan line trip used 205lts for the crossing.
