Page 684 of 1057 FirstFirst ... 682683684685686 ... LastLast
Results 6,831 to 6,840 of 10564
  1. #6831
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Fair enough.. not wrong about injectors price..
    But if your getting rough start and white smoke you may have a faulty one..
    Plan is to get a couple more mods done and then injectors / tune done.
  2. The Following User Says Thank You to sooty_10 For This Useful Post:
    BigRAWesty (14th August 2016)
  3. #6832
    My brother recommend to do the pump with injectors..
    If the pump is a bit work it could affect crack pressure and thus timing could be a bit out..
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    sooty_10 (15th August 2016)
  5. #6833
    Bendigo
    7 Post(s)
    Good advice I'll get it inspected most likely if it needs a freshen I'll weigh up a 12mm.
  6. The Following User Says Thank You to sooty_10 For This Useful Post:
  7. #6834
    Brought this one way valve for my Dawes set up
    will look heaps better than the OE one Im using now
  8. #6835
    Next big trip you go on throw some injector cleaner in the main tank.
    Thats what I do if going away
  10. #6836
    brisbane
    Fixed a crack in the windscreen with a super cheap kit and it's worked a treat
  11. #6837
    476 Post(s)
    wheres that valve go John?
  12. #6838
    going to put it in line replacing the OE one way valve in the Dawes set up
  13. #6839
    Expert Bloggsy's Avatar
    Perth WA
    On the weekend, fitted 4 x 4" ironman foam cell pro shocks, new front sway bar bushes (thanks to Mudski for supplying) and new nuts, bolts & sleeves for the front sway bar links.
  14. The Following User Says Thank You to Bloggsy For This Useful Post:
    Woof (17th August 2016)
  15. #6840
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    Finished installing new speakers in the doors. Went with 6 1/2 inch JVC CS-DR620`s, 50 watt nominal, 300 watt peak. Good match for the standard Clarion head unit. Got them for $45.95 a pair delivered on Ebay. http://www.ebay.com.au/itm/NEW-JVC-C...oAAOSww9VXhEoB These retail in the shops for around $70.00 a pair.
    Rear speakers sounded terrible at first, very tinny bass, this was caused by the inner door panel vibrating with the speaker. Fixed the problem by bracing the inner & outer skins with a block of styrofoam. Would recommend these to anyone looking to replace the standard speakers.
    Sounds great now, good to be able to listen to some decent tunes on those long trips.
    All set now for a new touchscreen head unit (will miss having a cassette player though!)
