Results 1 to 10 of 10
Thread: Removable Mud Flaps GQ
    Expert Forced Offroad's Avatar
    Apr 2011
    Logan/Daisy Hill
    what you need..
    Bunnings..
    30mm and 25mm box tubing.. Come in 1m lengths... Don't be alarmed with size its a snug fit..
    20mm flat bar... .................... " ".....
    Gal link chain..
    eye hooks
    Mud flaps are floor covering from Super cheap....
    2 x 40mm bolts
    1st
    Cut 30mm box section to suit x 2.
    Cut 25mm box @ 200mm x 2
    1st pic, is the straight bar welded on. This will have the mud flap bolted to it.
    2nd pic, I have the smaller box tube inside with 10mm left (reason 4 later) Drill a hole through both tube sections the same size as the bolt. put bolt through and slightly tightened. Then weld the nut to the tube. This make for your easy access and to undo.
    Capped off end
    Next setup up 10mm over hang end to chassi at your required hight and weld a tag.. adjust to your liking.
    Then weld the 25mm section to the chassi (2nd)
    See in this pic how it will slide over, with the already welded nut to the box tube it will make for easy removable of the mud flap by just undoing the bolt..
    See in pic (4) of the bolt which lines straight up and bolts in..
    Bolt on mud flap (in my case rubber floor mate)
    Chain it up to what suit your needs..
    Easy removal by undoing bolt and sliding out. slide to put back on and tighten bolt..
    Cheers Jay
    FORCED OFFROAD
    Built by NISSAN Powered by HOLDEN Perfected by ME "hulksta"
    http://www.youtube.com/watch?v=3GX2M...layer_embedded
    http://www.nissanpatrol.com.au/forum...Gq-v8-daul-cab.
  2. The Following 7 Users Say Thank You to Forced Offroad For This Useful Post:
    AB (27th April 2011), Bruza (6th May 2011), chester (27th April 2011), Finly Owner (20th April 2011), fixer982 (15th April 2012), growler2058 (25th April 2011), Silver (21st April 2011)
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    You're a champion mate - top job and great write up!!
  4. The Following User Says Thank You to Bigrig For This Useful Post:
    Forced Offroad (2nd May 2011)
    Apr 2011
    Logan/Daisy Hill
    Thnaks mate... Will add to it later when all finished and and chained up with the little extra bits I use to make it quick and easy..
    Also peeps, I have done a bottom rear quarter panel chop that mad it a lot easier. If you have not done this there is another way..just let me know and i will explain
    FORCED OFFROAD
  6. The Following User Says Thank You to Forced Offroad For This Useful Post:
  7. #4
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Great and simple solution to a annoying problem.
    Just be aware welding to a vehicle chassis may not be legal in some states, doing the same mudflaps, but with a "bolt on" version like a large U bolt as they use to mount sliders, would be another way to get the same results without any legal issues, bolt on would also allow you remove the support arm easy, should you happen to bend it off roading ?
  8. The Following User Says Thank You to 04OFF For This Useful Post:
  9. #5
    Feb 2011
    Shed
    45 Post(s)
    Bloody oath well done mate
  10. The Following User Says Thank You to growler2058 For This Useful Post:
  11. #6
    Apr 2011
    Logan/Daisy Hill
    Quote Originally Posted by 04OFF View Post
    Cheers for the heads up though mate,
    I do know that welding to the chassi can be a no no and I should have mentioned welding to the chassi could be not be legal.....but also if you get some serious rock sliders they weld a plat to the chassi as well to bolt on to....
    BUt in saying that Im sure there big enough and at the right hight I should not get pulled over for mud flaps being to short... (most states is 300mm from road to bottom of flap) and they wont check them out.....
    the way your looking at doing it as well will work and also looked into that way as well...this was easier for me..
    FORCED OFFROAD
  12. #7
    Legendary timbar's Avatar
    Feb 2011
    perth
    see theres thinking with ur head and not ur .... Good Work Mate
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
  13. The Following User Says Thank You to timbar For This Useful Post:
  14. #8
    Ripper post mate, another one for the list!!!
  15. The Following User Says Thank You to AB For This Useful Post:
  16. #9
    Beginner moo_r32's Avatar
    Apr 2011
    adelaide
    excelant idea mate.. simple too!!
  17. The Following User Says Thank You to moo_r32 For This Useful Post:
  18. #10
    great work there mate, top idea
  19. The Following User Says Thank You to Clunk For This Useful Post:
