Page 88 of 101 FirstFirst ... 8687888990 ... LastLast
Results 871 to 880 of 1003
Thread: Hodge's new 4.2
  1. #871
    177 Post(s)
    @Hodge what kind of tyres are you running on the patrol?
    My brother in law just purchased a new ford ranger and was looking at purchasing an aggressive all terrain type, and I recalled you had something similar and we're happy with them? Cheers
    I've got the Mickey Thompsons ATZ P3's mate. They are aggressive for an all terrain and i'm super impressed with them. Noiseless on the road but keeps up in the dirt no dramas. Had them on both my Patrols. Super happy.
    They now also have the Mud terrain P3's which are even more aggressive then mine.
  2. The Following User Says Thank You to Hodge For This Useful Post:
    Bacho86 (6th July 2016)
  3. #872
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Thanks Eric, I'll pass along the info. Cheers
  4. The Following User Says Thank You to Bacho86 For This Useful Post:
    Hodge (6th July 2016)
  5. #873
    177 Post(s)
    So after long procrastination she will be booked in for a clutch next week or week after.
    Few things on my mind though so, a question for the experts, as I really don't know.
    @nissannewby
    While everything is apart, what else should I be looking at getting done ?
    I'm reading everything from a main seal, welsh plugs, spigot, to a complete hydraulic slave and master assembly? Would these need to be done when the car has just clicked 100k ?
    I read somewhere the rear main seal can be real sensitive, and if one that's in good order is disturbed or replaced, it can leak after a while... more headaches then needed. Sometimes its best to leave it.
    Remember a while ago when I thought it was leaking and in the end it wasnt.... lol
    Flywheel machined ? Is this something that get's done anyway while it's apart, or do they look at it and then determine whether it needs doing or not ?
    The thing is, I don't even know whether my current factory clutch is farked or not, I'm sure you've read my "possible" symptoms earlier in this thread.
    So I'm throwing $ at it in a gamble, that it is farked, and last thing I need is to spend even more $$$ on other things which would be perfectly fine @ 100k. If they last me another 100k, I'd i'll die a happy man.
    Sorry for the long winded post, but I really want to get this one correct as it's not a cheap exercise, especially when I'm getting it replaced as a "hunch" that it is possibly farked.
    @mudski
    You had the spigot assembly when I bought the clutch of you didn't you? Still have it for sale ?
  6. #874
    I would at least do rear main seal, spigot bush and sump gasket. The sump gasket because it will be disturbed when doing the reat main. I have always done these when doing the clutch.
    You should have a new throwout bearing and spiggot bush in the clutch kit.
    The flywheel should be machined. It gives the new clutch plate a nice surface to bed into. Similar to honing a cylinder when new rings are installed.
  7. The Following User Says Thank You to nissannewby For This Useful Post:
    Hodge (15th July 2016)
  8. #875
    Your is fwrked mate. When i tried it, it was grabbing right at the end of the pedal, right at the end.
    I wouldn't bother with the hydraulic side of things, but do everything else as Mat has mentioned. And which spigot are you talking about?
    Hodge (16th July 2016)
  10. #876
    177 Post(s)
    Remember when I bought the clutch off you, you had a spigot assembly ( I think it was ) you offered and I said I won't need it lol.
  11. #877
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    When I did mine this is exactly what I replaced. Didn't worry about welch plugs etc. Maybe if it had 300k+ on it. Mine was @ about 150k.
  12. The Following User Says Thank You to sooty_10 For This Useful Post:
  13. #878
    Plus a great box for recovery or cooking gear win win eh imo
  14. #879
    177 Post(s)
    Made use of some sunshine.
    Fitted up some Boss tower braces... Task I've been procrastinating for a while now.
  15. The Following 4 Users Say Thank You to Hodge For This Useful Post:
    gaddy (27th August 2016), jff45 (27th August 2016), Stropp (27th August 2016), Touses (28th August 2016)
  16. #880
    @Hodge could you weld it also in afew places for better strength .
    how long did it take to fit, BTW
