Page 11 of 16 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 155
Thread: TD42t Engine Upgrades
  1. #101
    These sorts of ones. Have a thinner 14mm band to make it easier than the 19mm band ones.
    Cheers mate, I've seen those at pirtek and bearing wholesalers down here.
  2. #102
    I'm not sure Chappy's Avatar
    Jul 2014
    11 Post(s)
    She had her maiden voyage up the Hume tonight, sitting on 110 the whole way without a single bit of hesitation. Night and day difference from before. EGTs didn't go over 250 the whole time. My clutch is properly cooked now though, it's now started slipping in 3rd. I'll be babying it back home tomorrow.
    '96 GQ TD42t
  3. The Following 2 Users Say Thank You to Chappy For This Useful Post:
    AB (12th June 2016), BigRAWesty (12th June 2016)
  4. #103
    Jul 2014
    11 Post(s)
    Just ordered my UFI clutch, it should be here Monday/Tuesday.
    I had my airbox lid modified to fit the 4" K&N pod today too, will be nice to see if it makes a difference.
    '96 GQ TD42t
  5. The Following 4 Users Say Thank You to Chappy For This Useful Post:
    AB (15th June 2016), BigRAWesty (15th June 2016), Touses (16th June 2016), Winnie (15th June 2016)
  6. #104
    Quote Originally Posted by Chappy View Post
    I've done some calling around today, there's a place in Melbourne called Duggan Balancing who can lightening the flywheel by 2kg, balance the pressure plate and flywheel and machine it for $310. Does that seem like a good deal? This new clutch is quickly getting expensive..
    Bit of research shows these blokes are a good choice in Melbourne too Chappy.
    I'm still trying to save. Will be a slight miracle to get it all done before the trip but fingers crossed!!
  7. #105
    Jul 2014
    11 Post(s)
    That's good to know, thanks for looking into it. Hopefully you can make it happen in time! How badly is yours slipping?
    '96 GQ TD42t
  8. #106
    Not at all since the one flair but I'm heading to Fraser Island in September so I have to get it all done before then regardless.
    Too risky up there in sand.
  9. #107
    North brissy
    Remember to be well organised with this. The flywheel needs to be lightened and faced then the flywheel/clutch assembly balanced. So try to get everything booked in a way that it only takes a day or 2. Its achievable the last one I did we had the the flywheel out, lightened, faced, balanced and refitted in less than 48hrs.
  10. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    AB (16th June 2016), Chappy (17th June 2016)
  11. #108
    Jul 2014
    11 Post(s)
    Thanks mate, hopefully it all goes smoothly. I'm leaving it up to the business that's fitting my clutch to send it off to get it all balanced and machined etc. I've spoken to Duggan Balancing & I'll speak to them just prior to it being dropped off again just so they know exactly what I want. Thankfully it's not a daily so it's no biggie if it takes a week.
    '96 GQ TD42t
  12. #109
    North brissy
    What if it rains.....
  13. #110
    Jul 2014
    11 Post(s)
    What do you mean? It's Melbourne, it's always raining anyway
    '96 GQ TD42t
