Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 72
Thread: Alternator Warning Lamp Circuit Question
    snip...
    sense wire have connection issues or the fuse on it dies and the alternator puts out some 18+ volts.
    That kills the alternator dash warning light(assumption on my part).
    Your assumption is wrong, a sense wire fault won't blow the lamp
    When the alternator is running on all 3 phases the lamp has approx zero voltage drop which is why it goes out, 12, 14 or 18 volts doesn't matter
  2. The Following User Says Thank You to the evil twin For This Useful Post:
    dom14 (10th June 2016)
  3. #22
    84 Post(s)
    So you want to run a double redundancy system? Come on , do you really think a manufacturer would do that, unless it was for the luxury or military markets?
    Breakdowns keep the economy ticking over
  5. #23
    Legendary dom14's Avatar
    38 Post(s)
    I believe you. But, you still have to give me the facts behind your conclusion. Otherwise, I'll only keep annoying you here.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  6. #24
    38 Post(s)
    No argument there mate.
    The "typical altenator circuit" I downloaded from internet and uploaded here suggest two separate pins(wires) for warning lamp circuit & trigger/field/exciter circuit. So, I was guessing it's been already out there. It's that I just don't have it, 'cos I gota GQ?!
    Cheetah Outreach
  7. #25
    38 Post(s)
    Yeah, that would mean the regulator puts out "-18 volts"(on the lamp circuit) [or is it +18V] and that would roughly give -6V to the warning lamp(-18V+12V), so the warning lamp would come on, but nowhere near enough to cook it(I'm obviously speculating here with loose knowledge).
    Yeah, my argument was apparently based on a wrong assumption as well as poor understanding.(obviously forgetting the base fact of how the warning lamp circuit works)
    Does this mean mudnut's worry about alternator lamp blowing is NOT likely to happen?!!
    Cheetah Outreach
  8. #26
    38 Post(s)
    If I disconnect the sense wire, would the dashboard alternator warning light come on?!
    Cheetah Outreach
  9. #27
    Mar 2015
    a little knowledge can be very dangerous
  10. #28
    84 Post(s)
    I ain't worried about it. Just thought you would like to know about it, cause that is the sort of great guy I am
  11. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (11th June 2016)
  12. #29
    snip...
    Nope...
    If the Alt is putting out 18 volts at the Reg Diode Pack then that is also the voltage that will be (WRT earth or -ve if you prefer) at the B+ and therefore the Battery positive, the Ign cct and everywhere else in the vehicle.
    There will not be anywhere in the vehicle supply buss that is at 12 volts so there is no 18-12=6
  13. The Following User Says Thank You to the evil twin For This Useful Post:
  14. #30
    Quote Originally Posted by Makka View Post
    ROFL... and a lot can be bloody frightening
  15. The Following User Says Thank You to the evil twin For This Useful Post:
