Page 134 of 220 FirstFirst ... 132133134135136 ... LastLast
Results 1,331 to 1,340 of 2192
Thread: AB's new GQ is finally here
  1. #1331
    North brissy
    Forward entry for a front mount. Its all about the volume mostly. You can see how the entry pipe is against the back wall. It also has 300+mm from entry point with no restrictions (so no directional changes or wall). You need a minimum of 50mm all the way across. dont worry about tapering ends off etc just get the height for the volume. Centre entry should also follow the back wall.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    AB (4th June 2016)
  3. #1332
    North brissy
    BTW, looks very sexy!!!
    Who how and $$$ if possible lol
    Yep. It has 100mm of lift at the lowest point. Cost was about $450. I just used a fabricator we use through work up here. He doesnt do car stuff but I get special treatment lol.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    AB (4th June 2016)
  5. #1333
    Hey Mat what's the thread for on cylinder 4?
  6. The Following User Says Thank You to Winnie For This Useful Post:
    BigRAWesty (4th June 2016)
  7. #1334
    Probably just boost gauge, recirculation and pump?
  8. #1335
    North brissy
    For a clamp that holds the injector likes on later engines.
  9. #1336
    Where do you tap in for my comment above?
  10. #1337
    North brissy
    I will grab a pic soon and post it.
  11. The Following User Says Thank You to nissannewby For This Useful Post:
    AB (4th June 2016)
  12. #1338
    North brissy
    Reference lines go here for boost controller, compensator and boost gauge. With a spare.
  13. The Following 4 Users Say Thank You to nissannewby For This Useful Post:
    AB (4th June 2016), MB (5th June 2016), MudRunnerTD (5th June 2016), Winnie (4th June 2016)
  14. #1339
    Yeah right..that is way too neat!!!
  15. The Following User Says Thank You to AB For This Useful Post:
    MB (5th June 2016)
  16. #1340
    North brissy
    This is the bolt that winnie asked about. Its the bolt that looks closest to the head.
  17. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    AB (4th June 2016), BigRAWesty (5th June 2016), MB (5th June 2016)
