Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Sub Fuel Tank swap over.
    Yeah as Kallen said about the riser part on the GQ Aux tank. This part fouls with the floor on a GU, and I think the hole in the GU floor to access the sender unit doesn't line up with the GQ LRT.
    Yes, the holes are located in different places.
    Sent from my XT1033
  2. The Following 2 Users Say Thank You to jay see For This Useful Post:
    mudski (6th June 2016), Robo (27th May 2016)
  3. #12
    The gu had a hatch??
    Well there ya go
    Hardcore
    central coast nsw
    Well there ya go
    Hope it hatches out a dirty big V8 diesel
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  5. The Following 2 Users Say Thank You to Robo For This Useful Post:
    BigRAWesty (27th May 2016), gubigfish (7th June 2016)
  6. #14
    Ok so taken some pics today side by side..
    Unfortunately it's going to take more work than I deem worthy imo..
    The Lra tank needs to be shortened as the back of the tank will foul the cross member, the top hatch needs modifying, and then breather lines moved..
    Then (and I've never really niticed this) they hang hell low!!!
    Imo a tank needs to be level with the chassis.. the sub tanks seem to sit 50-60mm below...
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Robo (6th June 2016)
  8. #15
  9. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Robo (6th June 2016), Touses (6th June 2016)
  10. #16
    Hardcore
    central coast nsw
    Have a pic some where of the sub tank when I replaced the sender unit.
    but have attached a mod of your pic.
  11. The Following User Says Thank You to Robo For This Useful Post:
    BigRAWesty (6th June 2016)
  12. #17
    Hardcore
    central coast nsw
    Found partial pic of my GQ sub tank.
  13. #18
    Quote Originally Posted by Robo View Post
    Is that sender on a raiser?
    Hardcore
    central coast nsw
    Yes and guessing also the expansion area as it's completely flat otherwise.
  15. The Following User Says Thank You to Robo For This Useful Post:
    BigRAWesty (7th June 2016)
