Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Replacement Aeriel for my GU Patrol
    ... or go the Holden Antenna.
    A wire coat hanger bent in the shape of Straya jammed in the snapped off whip
  2. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Hodge (24th May 2016), LostBenji (25th May 2016)
  3. #12
    Quote Originally Posted by LostBenji View Post
    DAB+ means Digital Audio Broadcast, nothing to do with DTV.
    If you are running the factory head-unit, keep in mind that many run dual-diversity antennas meaning special plug into the radio. You can confirm by looking at the rear-passenger side glass for the antenna element (looks like a demister coil).
    Oops brain must have been on the blink.
  4. #13
    May 2016
    You could buy a powered 12v antenna like the ones
    used in hotrods and have it high up on the inside of the windshield.
    Similar to a single wire taped up high, still good reception or down low
    personal preference on placement, The antenna on my camper is a single wire
    running the length of the rubber seal for the hard lid
    Any actively boosted antennas can help but also cause more problems. To start with, you have to have a clean signal, weak is fine but as long as it is clear. If you run a booster it will boost all it hears. Unfortunately, this means if there is nearby noise either be a frequency near the FM band (VHF-low band) or other signals that are unwanted, these will get boosted as well. The trick is keeping the SNR (Signal to Noise Ratio) good.
    Compromised antennas (stubby rubber dildo's, short wire whips or those run in windows, roof cavities and the likes will also be a low performer. Not much chop for fringe areas.
    There is no legal cure for STUPID!
  5. #14
    Jun 2015
    Sydney, Australia
    The standard radio is dual diversity and is OK for reception. That being said, they still suck at time.
    The GME AEM2 (the bigger one) and AEM3 (smaller one) do work OK, just make sure they are away from other antennas.
    As for the VMS more info please, never heard of it.
    Yeah I wanted an all in one system so did quite a bit of research. There was basically the Hema one or the VMS one. The VMS system just does more and seemed to be a bit better. Basically it's a CD/DVD player, radio, Bluetooth and also has both on road and off road maps. Really nice. These are the details: http://www.vms4x4.com/collections/in...nissan-general.
  6. #15
    May 2016
    Not bad looking units. Mind you, I haven't found a sat-nav unit that beats my phone and google maps.
