Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
Thread: Belt Tensioner Assembly (CRD)
  1. #31
    .......... TPC's Avatar
    63 Post(s)
    I have changed it over and the noise is still there god damn it.
    Will get a mechanic to look at it now, may be what Threedogs said, the alternator clutch pulley.
  2. The Following 2 Users Say Thank You to TPC For This Useful Post:
    BigRAWesty (21st May 2016), growler2058 (21st May 2016)
  3. #32
    I'd say that's quite possible..
    But could also be the ac compressor..
    They are common too seeing they are quite low down..
    Feb 2011
    Shed
    45 Post(s)
    Same i feel your pain
  5. #34
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Maybe the belt is it after market or ome tip some water on it while running just a drop or 2 if it
    stops change the belt
  6. #35
    63 Post(s)
    Quote Originally Posted by roofy View Post
    That was my first thought but the belt is genuine and I did try giving it a squirt when I first heard the noise and it made no difference.
  7. #36
    TRAFALGAR VIC
    35 Post(s)
    Did the tensioner move freely when you put the belt on
    or did you need to pry the belt on as if to tight if so
    back the tensioner bolt of a tad to allow it to move freely
  8. #37
    That bearing is single row. The bearing in the OEM unit is double row. Made for high speed applications such as a tensioner.
    The OEM bearing size is 40mm OD x 17mm ID x 14mm wide...
    Here is some of the options
    • 62032RS 40 x 17 x 12 2 Rubber seals on the bearing cage, single Row, or
    • WC85703 40 x 17 x 14.3 Metal seals on the bearing cage, single row, or
    • LR5003-2RS 40 x 17 x 14, but the track of the bearing is slightly ball shaped, so not dead flat. 2 rubber seals, double row, or
    • 622032RS 40 x 17 x 16, 2 x rubber seals, single row.
    All the aftermarket tensioners just use the first option. Thats why they fail so fast.
    These are for the direct injection tensioners. Not sure about the CRD. But I believe its the same, just a smaller OD pulley wheel.
  9. #38
    63 Post(s)
    The tensioner moved freely when I put it on, I am confident nothing is too tight.
  10. #39
    TRAFALGAR VIC
    35 Post(s)
    Have got a spare belt id try that first if not it will be the alternator
  11. #40
    I could not find the pulley only so have bought pulley and tensioner on eBay from this mob.
    http://www.ebay.com.au/itm/Genuine-E...kAAOSwd0BV1ZEU
    New belt too? Or just the tensioner?
