Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Cracked Fuel Tank
    Apr 2015
    Perth
    Cracked Fuel Tank
    Hey guys and gals
    Noticed today that there is a small crack in the long range tank on my 2011 patrol. The crack is on the front side of the tank and is about 10mm long going horizontaly. Would like to get it sorted pretty soon as it leaks when I fill the tank up past a certain point.
    Just wondering how it can be fixed and if I would be able to do it myself or would have to take it to somebody.
    Thanks in advance
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    best Idea would be to take it to someone - but they will tell you what you already know - its stuffed
    quick fix, which will get you out of trouble in the short term
    thoroughly clean around the crack, all paint, dirt, fuel, etc
    get a stick of Palmolive soap
    rub it into the crack as much as you can
    leave it for awhile, then jack the rear up, so its at an angle you know the fuel will be over the crack
    if no leaks - good, clean around the area well, and use some Kneed It over the top of the crack
    http://www.selleys.com.au/putty/epox...multi-purpose/
    if leaks - not so good
    the above will get you out of trouble in the short term, as I said
    but
    best Idea, take it in and get it fixed properly
    No offense but if your asking how I'd take it to a welder.
    They'll need to clean the tank out and then weld it.
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Bigcol (1st May 2016)
    84 Post(s)
    There are some of those two part putties that should suit a fuel tank. I used some on a steel fuel line that lasted for years but .
    is really just a quick fix. As Kallen wrote an experienced welder should fix it.
    I would also check the tank mounts to find out why it started cracking in the first place.
    177 Post(s)
    Graham Cahill recently used that 2 part putty that literally turns into solid metal over the crack in his diesel tank. It was on their Kimberley DVD, but the fix was only worth a day or so driving.
    Legendary dom14's Avatar
    38 Post(s)
    I'm just wondering the reason the epoxy putty doesn't work on steel tanks.
    I've used epoxy to patch up a jerry can. It's been going for years without leaks.
    How would a long range tank crack?!!! Must be from an impact!
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  8. #7
    Apr 2015
    Perth
    Yea looks like it might have been from a rock flicking up
  9. The Following User Says Thank You to cass_cass94 For This Useful Post:
    BigRAWesty (8th May 2016)
  10. #8
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Weld it up.
    If you can get to the crack while the tank is still in place.
    Drain fuel 100%, make sure it is all out and purg with exhaust gases or warm nitrogen gas.
    Once purged and dry and while being purged you can weld in place.
    2012 GU8
  11. #9
    Quote Originally Posted by cass_cass94 View Post
    So any progress?
    38 Post(s)
    Quote Originally Posted by rusty00 View Post
    Weld it up.
    How do you "purge" with exhaust gas? Where do you get nitrogen gas to purge the tank?
    Cheetah Outreach
