Page 259 of 570 FirstFirst ... 257258259260261 ... LastLast
Results 2,581 to 2,590 of 5698
  1. #2581
    way too fiddly fo my eyes a good soldered joint with some heat shrink should work.
  2. #2582
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    For a normal city car yes. BUT for one that sees dirt/mud joined wires are the worst.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  3. #2583
    New tensioner for the gu..
    And belt..
    Going to rebuild the old one..
    Ordered a new RH CV and wheel bearings yesty. Hopefully they should be there today for pickup so I can put it all back together.
  5. #2585
    177 Post(s)
    When will you be doing them once they arrive Mark? Would love to see how it's done.
    It was supposed to arrive last night at CBC. They didnt ring. I will ring them in a few minutes. Hopefully its there. With the wheel bearings, i will pick them up and then start it today.
    Hodge (27th April 2016)
  8. #2587
    Oct 2010
    Old Bar, NSW
    Now there's a thing...
    I have always wondered what the purpose is of pre-assembled Weatherproof Connector that has to have the equipment wires crimped/spliced/whatever in about 2 inches away from the connector.
    That now means you have 3 connections where you only need 1 (splice to connection to splice instead of just a connection)
    Wouldn't you be better off buying the Weatherproof Connector and just assemble it with the original equipment wires ?
    Years ago I helped a fellow sparky wire a flash boat, real flash it was. We had insulated crimp connectors you know the red, blue and yellow ones.
    But, they were grease filled with a seal that the cable was pushed through into the connector then crimped.
    Were supposed to be waterproof and corrosion resistant.
    Can they still be sourced?
    Macca
  9. #2588
    Hey mate, yeah they are available. Hideously expensive of course but certainly available. I would think a solder join and some resin filled heatshrink would be the easiest method for joining onto these.
    But of course it is another unnecessary join.
  10. #2589
    Standard and mil spec duetsch plugs are the go. Can you source these winnie?
  11. #2590
    Probably. I reckon they'd be cheaper and quicker to get online though.
