Page 26 of 44 FirstFirst ... 2425262728 ... LastLast
Results 251 to 260 of 434
Thread: Threedogs motor thread
  1. #251
    The hose split along almost its entire length and as it happened just as I was entering the town I coasted into the garage and the mechanic took over from there. Lucky it happened where it did or I would have had to muck about with it to get it going, or use my RACV total care to come to the rescue.
    Just sayin' for future issues or for others...
    Any hose same dia will do, you can even chop up the 'outlet' hose if needs be
    Thats also why I carry a couple of inches of offcuts in my emergency kit
    This new fangled idea where the water circulates continuously you need to block inlet and return
    Old school was even easier, just loop the pipes or turn off the heater tap you only had to block the return.
    An EH Holden I had went for months with a whittled down piece of gum tree branch as a bung when the heater core split.
  2. #252
    Ha Ha,,,have you seen the "stuff" that comes out of a blocked EH heater core yuk lol
  3. #253
    Ha Ha,,,have you seen the "stuff" that comes out of a block EH heater core yuk lol
    The girlfriend sure did... dunno why I got the blame I wasn't wearing the white slack suit and she was the one who turned it on.
    I mean to say when something hysterically funny like that happens it takes a while for a bloke to stop laughing.
    Ah well, it wasn't meant to be, no sense of humour, fantastic set of t... uuummmm... toenails but no sense of funny at all
  4. The Following 4 Users Say Thank You to the evil twin For This Useful Post:
    Kimbo63 (22nd April 2016), mudnut (22nd April 2016), threedogs (22nd April 2016), Touses (23rd April 2016)
  5. #254
    Quote Originally Posted by Kimbo63 View Post
    Or carry a couple of blanking caps better still fit a couple of taps on the outlets might even make the air conditioning run a bit cooler
    Or keep some 5/8 barb joiners in your tool box...
    Ive been thinking about running a heater tap on my GU, somewhere, so when the temp control is set to cool, the tap will just close off the system and recirculate the coolant through the tap. As im not sure if there would be any detrimental affect to just blocking the heater hose.
    Having a heater tap would solve the warm air issues with these GU's i reckon.
  6. #255
    snip...
    Yeah... pain in the rrse isn't it.
  7. #256
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Can't see it having any effect on the cooling system having two taps on the hoses where they come out of the block turn off in summer and back on for winter we did this to all the excavators made a big difference to the performance of the aircond
  8. #257
    Mate. Mate! In cab style I want. Turn the temp to cold and off she goes.... Got it half worked out in my head.... But I wont trash this thread about it....
    Kimbo63 (23rd April 2016)
  10. #258
    Oct 2010
    Old Bar, NSW
    Suffered with this too, fitted an electric valve in the heater water circuit. It doesnt effect the cooling system at all.
    The warm air still enters the cab! it comes from across the bonnet into the fresh air grill where the wipers are.
    At speed its not a problem, but slow running in the bush or traffic the warm air above the bonnet is the source.
    Macca
  11. The Following 2 Users Say Thank You to macca For This Useful Post:
    mudski (23rd April 2016), threedogs (23rd April 2016)
  12. #259
    So what was the actual original problem?
    Started off with Sub Tank Warning Light was on all the time...
    Using a logical fault-finding technique to make sure we don't miss anything we are working our way thru the alphabet.
    We have got to 'R' for Radiator so should have it sorted in under 300 posts if all goes well
    Only problem on the horizon is when we get to 'S' for Sarcasm (bloody dirty thankless task that is so not looking forward to that at all)
  13. The Following 5 Users Say Thank You to the evil twin For This Useful Post:
    4bye4 (23rd April 2016), Bacho86 (23rd April 2016), BigRAWesty (27th April 2016), gaddy (23rd April 2016), Touses (23rd April 2016)
  14. #260
    Any updates John? How are the temps? Any more water leaks?
