Page 255 of 570 FirstFirst ... 253254255256257 ... LastLast
Results 2,541 to 2,550 of 5693
  1. #2541
    I'm really struggling to find some sorta flush pannel mount air fitting now though......
    I may just need to have a regular fitting...
    You may need to tig weld a recessed one if you know what I mean.
    About 100mm x 100mm plate,,, You know,,, just flicking ideas at you
  3. #2543
    That's what I'm thinking.. I do have plenty of stainless in the shed..
    And pm replied mate.
    Sooooooooooooooooooooo,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,? lol
    You know it will 1 look good and 2 every one will want one
    Could even fit a pressure gauge there as well or run one up
    to the cabin area
    What have you done to that pull out tab area in the back??
  5. #2545
    Not accessible with the draws. The metal sides don't allow access..
    I was looking at something like this..
    But it would make the hose only usable in my car..
    Wouldn't you use the female end with a 1/2" bsp washer holding it tight.
    On the troopy I had outlets front and rear, but you need to terminate them
    with a female fitting, Then your air hose has the nitto male fitting one end
    and a nitto female the other end, That way all your tools will have a Nitto
    male screwed to them. Hope that makes sense <<<<<<<<<<<<<<<??
    So basically your air gun[blower] your rattle gun, and inflation tool will all
    have a male nitto fitted to them, All you need is a short piece of high pressure hose
    that will reach all wheels with a female at one end and male nitto at the other end.
    Length is normally about 2.2 mtrs long
    At the back I had air and water very handy indeed
  7. #2547
    Yea I probably will as they do have a female pannel mount fitting..
    Only going the one outlet in the cabin now..
    Dropped the other idea.. keeping it simple..
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Apparently, today I bought a resleeved block, tested and revalved head, a balanced crank,
    Balanced flywheel and clutch, 3" exhaust and a garrett 2863 turbo. Apparently!
    My wallet hurts. I'm going home to drink beer.
  9. The Following 2 Users Say Thank You to Touses For This Useful Post:
    BigRAWesty (11th April 2016), threedogs (11th April 2016)
  10. #2549
    Brought some twist lock weatherproof 2 core connectors,
    Trying something different fo my awning lights, 6 watt coloured cob lights
    Ill put the link later,,, these connectors are perfect for any outdoor project
    I only brought 2, wish I'd brought more.
    http://www.ebay.com.au/itm/251913657...%3AMEBIDX%3AIT
  11. The Following User Says Thank You to threedogs For This Useful Post:
    ova50 (11th April 2016)
  12. #2550
    476 Post(s)
    Quote Originally Posted by Touses View Post
    Zoom zoom! It will be worth it though.
    I just bought two new brew head seals for my coffee machine... Lol. I need ma coffee!
  13. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (11th April 2016), Touses (12th April 2016)
