Page 625 of 1057 FirstFirst ... 623624625626627 ... LastLast
Results 6,241 to 6,250 of 10565
  1. #6241
    beasts/nags :-)
    I have 2 days of barrel racing to attend sat and sun.
  2. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    MB (24th March 2016), threedogs (25th March 2016)
  3. #6242
    And we wonder why we can't finish our Patrol projects :-) lol !!
  4. The Following User Says Thank You to MB For This Useful Post:
    Winnie (25th March 2016)
  5. #6243
    476 Post(s)
    Bugger me Mudski,
    I honestly can't keep up with the dedicated good work and time you put into the beast !
    Slow down old mate, I'm sure she's already beyond perfect :-) !
    Inspirational :-) !!!!!
    Cheers MB
    Cheers Mark. I just hate having things that are not quite right. I've always been like thing with every vehicle I have owned. Its the only thing I take pride in. Apart from my two beautiful daughters of course.... Lol. Next I want to see if I can vinyl weld somehow. Haven't Googled it yet but I'm sure theres a way. I have a small tear in one of the door trims which calls out to me everytime i get in the car and pokes its tongue out. No wreckers have the right trim I need. Or they do and its worse than mine.
    I dont mean to be a pain but if they arent you should use high tensile washers. Also use cone lock nuts instead of nylock especially for suspension bolts.
    And use plenty of anti seize on assembly.
    The black washers are supposed to be. I asked for High tensile. So I can only assume they are. The silver ones I know are not. Prolly should have got high tensile for there. put that on the list... And for the nuts. To be honest I didn't think about using cone nuts. I will get those instead now. Thanks Mat... And I am in the process of pulling every suspension bolt out and applying Never Seize to the bolts. I swore by this stuff when using it on the axle shafts of my dirt bikes. Makes life soooo much easier when you need to remove a wheel to repair a flat in the middle of the bush.
    I had to replace two bushes on the rear rh lower trialing arm only because the bolt was dry and it was grabbing on the inside of the bush and on full flex it just ripped the inside of the bush.
    Live and learn mate...
  7. #6244
    You're a legend Mudski, dedication :-) !!!!!
    mudski (24th March 2016)
  9. #6245
    You must have been typing that when i edited my post.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
  11. #6246
    Oct 2010
    Old Bar, NSW
    Hmm o.k. So maybe they didn't over charge me. Lol. I was charged $80.... The mob I work for 15years sold bolts, imperial size only though. And I know they they charge around $3 for a 3/4inch x 4inch bolt, grade 8 etc etc. I'm in the wrong business. Feck!
    Needed a large HiTensile plus washers and nut for someting a while back, cost $16.00 each FFS!
    Macca
  12. #6247
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Anti seize Is a must - I use it on everything - including cable ties haha , not really but you get my drift .
    2002 GU wagon 3.0lt , auto , piranha dual batteries , 3" lift , chip , needle & Dawes valves - just gettin started
  13. #6248
    476 Post(s)
    Well i made a dogs breakfast welding two washers to the first bracket. Doesnt help when im supposed to be going out in an hour and im welding upside down and my arms twisted the wrong way. I can weld pretty good if im sitting or standing straight... lol
    So ill have to cut these off and do it again soon.
    With more time and thought about how to go about it.
  14. #6249
    22 Post(s)
    so no pic of your overhead welds then?
    96 GQ coil/Cab
    08 G6eT
  15. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Rossco (25th March 2016)
  16. #6250
    476 Post(s)
    Ahh. No....
