Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Awning mounting
    477 Post(s)
    Quote Originally Posted by beexy View Post
    Thanks three dogs. I am a stubborn male so I'll see how we go haha.
    Mudski, is that the L bracket with a longer bolt on the top to a drilled hole?
    No L brackets mate. A short bolt slides into the bottom rail of the awning, a longer one in the top. Then two hole drilled into the side upright of the rack.... Thats all... You can see the top bolt has a nut and a washer holding the bolt in the rail so it doesn't move when trying to mount the awning. Then there is another nut you can see, which is on the outside section of the upright, then another nut on the inside of the upright. Hope that makes sense.
  2. #12
    Oct 2011
    melbourne
    Thanks to the both of you. Makes sense mudski. Might give that a go. Three dogs is mounted on the passenger side.
  3. #13
    The bolt you need is a 6mm stainless would be choice of steel
    seeing its out in the elements all the time..Good luck
  4. #14
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Mine is mounted on the same angle. I've never had a problem, though next time I'd do similar to mudski
    Lucus30's 1999 GU ST TB45E
  5. The Following User Says Thank You to lucus30 For This Useful Post:
    mudski (16th February 2016)
  6. #15
    477 Post(s)
    Quote Originally Posted by lucus30 View Post
    My rear awning is not like my side one and it does point up. I keep meaning to correct it as i nearly broke it one day on and off camber slope of ground i decided to use it on
    And yeah as TD said. Use stainless steel bolts.
  7. #16
    Oct 2011
    melbourne
    Went with the mudski method and has quelled a treat. Thanks all for your input.
  8. The Following User Says Thank You to beexy For This Useful Post:
    BigRAWesty (19th February 2016)
