Page 123 of 187 FirstFirst ... 121122123124125 ... LastLast
Results 1,221 to 1,230 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1221
    If you build them properly and still damage them enough to rebuild or replace sections, there will be more pressing issues that need attention before the barwork.
    I tagged you in a set this morning, they're good. I personally navigated the owner into a position where they were needed to do their job and they did it just fine
    I can't wait to get these things on mate, the last few times i have had the GQ out i have done big panel damage, These are designed to protect me from that. I don't expect to damage my bar work, its solid but i do expect to lean on it regularly, its just where we drive. Roof Sliders for the win
    The Camburgs will make giving bar work a fresh coat of paint easy which will be great.
    You didn't tag me this morning mate.... Share!
    Lights (10th February 2016)
  3. #1222
    22 Post(s)
    Check your facebook. I just tagged you in that post.
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    MudRunnerTD (10th February 2016)
  5. #1223
    Cheers mate, just had a look. That is identical to what I have bent up for My GQ and ABs GQ. I used 40nb 3.2mm wall (48.3mm) which looks a little heavier than that bar work. But basically identical.
  6. #1224
    22 Post(s)
    Yeah thats heavy wall 32nb. Keeps they weight down a bit and still lets you get to the fuel filler. Obviously not a huge difference in size but it is tight around the filler. You'll have ro remove the filler cap
    96 GQ coil/Cab
    08 G6eT
  7. #1225
    40nb with 3.2mm should only be 46.4mm od?
  8. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (11th February 2016), MudRunnerTD (10th February 2016)
  9. #1226
    Yes you are right. I was told it was 48.4 but I have not measured it. The dies suit this pipe exactly.
  10. #1227
    Yea most dies are made for standard pipe sizes..
    It's going to be interesting doing 40mm stainless which is actually 38.9mm od in a 32nb die 39.5mm..
    Might need to shim it..
    we should also weld that extra support on the rear scrub down to the rear bar as well.
  12. #1229
    MudRunnerTD (11th February 2016)
  14. #1230
    Good link there Mark. Cheers.
    48.3 it is.
  15. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    nissannewby (12th February 2016)
