Page 55 of 101 FirstFirst ... 5354555657 ... LastLast
Results 541 to 550 of 1003
Thread: Hodge's new 4.2
  1. #541
    177 Post(s)
    Cheers Rod.
    I drove the same route back in september. But i had stock wheels and tyres and had no roof rack. I also didn't have the gauges, so have no clue what temps were doing and yeah it was fine with those hills. However, it's Different now ...
    As I said, I'm not after nor do I expect super power from it. I am 90% positive I won't be towing a caravan or camper trailer or anything for many years to come . I'd just like to have it running "right" . If that makes sense. I'm happy to drive it around like a truck chugging along...
    But yeah, after this weekend gone I need to do something...
    Matt, it never ever crossed my mind about the diffs. I will do some reading as I'm fairly naive when it comes to that. Cheers.
    Patrol Guru Rocket55's Avatar
    Sydney
    I was on standard gearing and 33's (still am). 3" exhaust, 12-13psi and get it tuned and it'll be heaps better than stock. That's how mine was when I picked it up and I drove Melbourne to Sydney on cruise in 5th the whole way, maybe except for 1-2 hills.
    Cheers Rod
    My Build 2005 TD42TI
  3. #543
    http://www.ebay.com.au/itm/BLUE-ANDE...item4d2aa7adcd
    This may be ok for your solar plug at the front, I just brought the red one it is lockable and has led lights
  4. #544
    What sat on 21c surely not water temp. and water temps will have nothing to do with your EGTs.
    Id think your water temps should be about 85c to 90c
  5. #545
    177 Post(s)
    Nah the gauge or the redarc gauge receiver is broken so it's always frozen on 21 now ... so couldn't get true coolant Temps.
    Water Temps will be influenced by egts. Engine gets hot from egts which in turn heats up the cooling system. ..
    Tapatalked from S6
    These red arc gauges dont really seem to be worth the while
  7. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    Bloodyaussie (9th February 2016), Hodge (9th February 2016), Winnie (9th February 2016)
  8. #547
    Tapatalked from S6
    Your thermostat will regulate your water temps
  9. #548
    Thomastown, Melbourne
    6 Post(s)
    I have heard a number of people with issues with red arc and hard to justify the cost when the reliability is not there.
  10. The Following 2 Users Say Thank You to Bloodyaussie For This Useful Post:
    Hodge (9th February 2016), jay see (9th February 2016)
  11. #549
    Thermostat regulates flow which allows more flow to radiator thus exchanging the higher temps.
    The cooling system can only do so much. If egts are sustained at 450+ degrees for a long time they will have an effect on coolant temperature if the system cannot cope.
  12. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Hodge (9th February 2016), threedogs (9th February 2016)
  13. #550
    Yeah I noticed this on my trip up the south coast of NSW. If I kept my EGT's under 240c, my water temps would sit on 90c, sometimes 85c. If I held the EGT's at 260c, my water temps would rise 5c.
  14. The Following 2 Users Say Thank You to mudski For This Useful Post:
