Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Gu cruise control
    Advanced Dannyboyz's Avatar
    Jan 2016
    Gu cruise control
    Hey guys, I'm planning a trip up to darwin from Vic mid year in the 98 TD42 wagon and really want to fit it with cruise to stop the right foot cramping. I have seen the d shape controller that fits in the right hand side of the steering wheel on other Gu's and wondering if anyone can tell me what brand they are and where to get one, I have looked on ebay and can only find kits for 3lts in later models. Also interested in any other kits blokes may be running that work well.
    Thanks, Danny
    I've always gone with AP60 for the GU's.
    Never had a problem and they fit up fairly neat
    http://www.ebay.com.au/itm/CRUISE-CO...QAAMXQfvlSgGoh
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    BigRAWesty (30th January 2016)
    When I was looking at fitting cruise to the q it seemed the AP60 was the pick..
    That was a few years ago now so things could have changed..
    The AP60 is a good setup, but tap it into the spedo cable wire to the dash, the magnets on the drive line tend to fail to often
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    the evil twin (30th January 2016)
    Jan 2016
    Thank you guys, have see this kit in the autobarn how ever not as cheap as that link, are they hard to fit? I'm no mechanic or auto elec but there isn't much on the troll I haven't been able to fumble my way though yet
    Dec 2015
    WA
    5 Post(s)
    I have had 2x AP50 (older model) systems one on a 1990 Hilux & one on a GU2 (servo pulling the accelerator in the cab), they are great units, if you have got a manual you will need to install a clutch switch, there is a mounting hole ready for it. Back up from the Command Auto is fantastic, when my servo cable broke (chaffed through, should have installed it better) they sent me a new servo at minimal cost. If you give Command Auto Group a call they can advise you on what you need.
    BTW the AP50 held the speed within 1km/h on the GPS, factory cruise is 2 to 3 km/h.
    Graham
  8. The Following User Says Thank You to GeeYou8 For This Useful Post:
  9. #6
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Has anyone tried the AP300 cruise on an early GU? Apparently they can use the gearbox sensor or speedo signals etc and are calibrated through the cruise unit. Not reliant on pulse rates or something. Might be a more secure method than the magnets?
    http://pages.ebay.com/link/?nav=item...789550&alt=web
  10. #7
    Nah, sorry mate can't help on that one.
  11. #8
    Dec 2015
    WA
    5 Post(s)
    I don't remember the model, but they did make one for the ZD30 (GU2) that uses speedo pulses & electronic throttle control so there is no mechanical cable.
    When I enquired it had to be installed by a Command Auto dealer.
    Graham
  12. The Following User Says Thank You to GeeYou8 For This Useful Post:
    BigRAWesty (31st January 2016)
  13. #9
    Jan 2016
    Hey guys, I finally got the ap60 cruise kit and began to fit it this weekend, just a few questions if anyone has fitted one, where should I get the vacuum from for the actuator? And can anyone point me in the direction of the speedo cable wire that Kallan mentioned earlier in the thread? I looked at fitting the magnets on the drive shaft but it just looks too hard to fit and too easy to fail!
  14. #10
    If you have AC grab the vacume from the ac idle up unit..
    And hunt for the speed sender unit. Pretty sure it's on the gearbox.
