Results 1 to 10 of 17
Thread: GQ back seats moved back
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Has anyone out there in patrol land moved the seats in a GQ back? When I have my seat back as far as it will go (a couple of extra inches would be better) the young bloke has no room in the back.
    I want to move the back seats back a few inches.
    Any ideas???
    84 Post(s)
    Sorry, Covo, I had the same problem and ended up leaving the third row seat in so at least the kids could stretch out side ways. Very interested to see if anyone has come up
    with a solution too.
    Dec 2012
    Coffs Harbour
    Just about ready to rip the last row out. If it stops raining they are goneski!
  4. The Following User Says Thank You to Covo71 For This Useful Post:
    mudnut (30th January 2016)
    There was a thread recently of modded brackets to move the front seats back for you 6'2" plus guys
    I really cant see why the same cant be done on the rear seats,
    Make a frame that picks up all std mounting points and move the seat back on that.
    Id have to have a look but Im sure its possible, you may need to remove the seats from the rails
    to allow you to bolt to the new frame??
    Dec 2012
    Coffs Harbour
    The floor goes up not far behind the bracket at the back of the seats.
    I was thinking of just getting some 5mm steel and running it along the top of the existing bracket past the back about 100mm and bolting the seat further back on the steel. Both the kids are in car seat bolting in behind that so don't think there are any safety issues.
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I dont have pictures, as I have sold the car, but
    I did do this mod on my GQ
    you need to take them out
    basically, the front edge of the bracket that the seat base swings on, we cut the front off and moved it back 60mm into the middle of the bracket......... I hope this sort of explains it........ instead of the bracket that is bolted to the floor being an "L" shape, it is now a "T" shape - bolt holes on either side of the center section......... aaaahhhhhhhh how to explain.......?????????
    you also need to remove the "bump stop" at the back of the seat, and turn the locking bracket for the seat base around for the seat to lock down properly
    should also say, that if you have a cargo barrier, it will also need to be moved back and modified
    I am thinking this is in English, so hopefully you will understand
    but I think I am thinking in Gibberish.......................
    be carefull when you take the seat out, you may need to weld up the cracks under there first
    Last edited by MudRunnerTD; 31st January 2016 at 08:50 PM. Reason: Fixed the photos for you mate
  8. The Following User Says Thank You to Bigcol For This Useful Post:
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    dunno why it wont show the pictures...........
  10. #8
    Dec 2012
    Coffs Harbour
    Quote Originally Posted by Bigcol View Post
    You can open each photo
  11. The Following User Says Thank You to Covo71 For This Useful Post:
    Bigcol (31st January 2016)
  12. #9
    Dec 2012
    Coffs Harbour
    Hey Bigcol,
    Was 60mm enough or can you go a bit further?
  13. #10
    Who did the work for you Col, was it XLR8?
